Bush Hog repair question
/ Bush Hog repair question
It’s slotted to slip over a key in the shaft. I’m going to try to get it off tomorrow. I can see what a local machine shop would charge to duplicate it vs welding. I don’t know if a local welder will touch it for liability reasons.
/ Bush Hog repair question #23
Its running at 100 mph shouldn't be flying :unsure:
willy
/ Bush Hog repair question #24
For cash no ticket, out the door, they will.
/ Bush Hog repair question #25
I am a welder....but I wouldnt weld that.
I dont care what anyone says....but a weld is never as good as virgin metal. Sure the "weld" may be stronger.....but the heat affected zone of the bar is gonna become a new weak area.
Take it off. If its splined, see if you can match a replacement via other sources. If its a simple keyed hole, or even tapered and keyed....might be easier for a machine shop to replace
I would weld it all day long.
/ Bush Hog repair question #26
Don't fight that all day. Just loosen or take nut off bottom and go cut grass with it. Blades will fall off. That's the way I do all of them.
/ Bush Hog repair question #27
Good weld or bad weld, I wouldn't weld it, simply because you are still going to have the same issue that you had before. I would look into finding a stump jumper for it and upgrade your Bush Hog by doing that! I have used bush hogs without a stump jumper, but we don't have rocks in this part of Florida, so the biggest worry I have is trash thrown out by people.
David from jax
/ Bush Hog repair question #28
When it let go on a friends machine it took out his back tire. So he still had to get the repair part for his BH and replace a 16.9x24 loaded tire. No savings there.
He had repaired his to.
Weld was good but it broke beyond the weld. If you're adding metal pieces to strengthen the area you're throwing the balance out. Run an unbalanced blade and you'll destroy the rest of the machine in no time. If you can stand the vibration riding on the tractor.
/ Bush Hog repair question #29
Let's do a little math ... The blade is turning a 6 foot circle. Don't know the gear box ratio.. so lets say 1 to 1 then, the blade is turning at 540 rpm.
What's the tip speed ? 6x3.14x540=10,173.6 feet per minute.
How fast is that? 10,173.6 /5280 = 1.93 miles / minute
My car speedo reads miles/hour so...1.93x60=115.8 miles per hour.
I can then say... the approx 25 pounds of half blade holder plus attached blade is moving around 100 mph when it lets loose.
I won't be standing in it's path. Would you ?
Wild speculation.
The "tip speed" is irrelevant. The tip, is connected to the rest of the blade. The blade, is connected to the shaft. The shaft is likely half the speed of the pto output due to the gearbox on the brush hog.
No need to be so dramatic about it.
And since you completely ignored it the first time I posted, I WOULD GET A STUMP JUMPER!
Jeeze, some people's kids.
OP, have it welded, put a stump jumper on it, and move on.
/ Bush Hog repair question #30
2:1 is ratio for bush hog. Cheap off brand cutters are 1.5:1
not on a 6' cutter. 1.5:1 would be on the high end of blade speed....~16000fpm 1:1 would be on the lower end.
And "cheap" or "off brand" has nothing to do with gearbox selection. I had a 306 bushhog with a 1:1 gearbox
/ Bush Hog repair question #31
Looking at soe parts diagrams, it looks like the bushhog 266 has the tapered hole and not splined. with a keyway.
Alot easier to make than a tapered splined hub.
Just a bar of steel with three holes. Two round with keyway for blade bolts and the center hole tapered with keyway for the gearbox.
I still wouldnt weld it. Too many unknowns like true RPM, blade weight, etc. But just off the cuff.....about 10,000 pounds of force on that weld as a result of nothing more than speed and RPM. Sure....it would hold on something like that....but now throw in shock loading like hitting a stump or a rock.....impossible to calculate.
It obviously broke once....and a repaired part is not going to be as strong as original....so if you replicate what happened that made it break the first time....there is about a 99.99% chance it will happen again.
Even if you only ever plan on using this out in the middle of nowhere, and no one within a thousand feet and no buildings.....how much does a new rear tire cost? Because I have blades come off and go through the sidewalls of a rear tractor tire like it aint even there. Is it worth the risk to you?
Dont know the dimensions....but have you tried to locate an aftermarket stump jumper/blade carrier assembly?
/ Bush Hog repair question #32
Which crack? The fresh one on the RH side or the one on the LH side that’s already been repaired at least once in its life? If you’re going to say that left side hasn’t been welded, then it has suffered enough damage to have bent/warped/twisted/stretched the bar in that spot, and as such, it now will also be a weak point that is subject to failure.
So after you weld the bar, do you plan on laying a bead down for some added weight on the other side, or what was your plan to ensure things are balanced? Not being balanced you’ll throw off the gearbox and risk damage to more than just the area adjacent to the fresh weld. You did mentioned balancing it, but I wasn’t sure of your plan or the plan those individuals had who suggested to beef up the design. That’s a whole lot of grinding to clean up the metal good enough to lay a “suitable” bead. Plus you would want it clean enough to look for other cracks.
How much do you think the BH is worth if it were in working condition - - as in If the bar were not damaged?
Would it be worth buying a new bar or having one machined, then sell the BH to recoup your investment or having one machined and buying a stump jumper for it? Personally I wouldn’t be operating one without a stump jumper.
What kind of shielding do you have on that BH?
/ Bush Hog repair question #33
How much for an ER trip and loss of lower leg?
/ Bush Hog repair question #34
If it ain't two to one I'll pass on it. I've handled too many to put up with that.
/ Bush Hog repair question #36
Now tell me how you can possibly lose a lower leg.
A person could be a bystander several feet away or an unlucky operator.
Several years ago, a SUV hit a metal sign base on I20 outside Atlanta. When it was hit, it cut the tire & took a divot from the cast right front wheel. Then it proceeded to slash the passenger side of the vehicle like a giant can opener.
It's flight wasn't a straight line. That same piece cut through my radiator & headlamp. A few inches higher, and I wouldn't be typing this.
/ Bush Hog repair question #37
And "cheap" or "off brand" has nothing to do with gearbox selection. I had a 306 bushhog with a 1:1 gearbox, per Johnny dear. I have a J D right here that is 2:
1.38:1, 1.68:1. Were J D ratios.
/ Bush Hog repair question #38
You wrote some things. But explain how I can be sitting on a tractor and lose my leg from a bush hog blade.
/ Bush Hog repair question #39
When I started working, we had Roanoke grader mounted bushcutters, they were deadly. The problem with them was you had to have the grader engine reving so fast to get the head speed up, you were travelling to fast to safely control the head position. This isn't one we worked on, it's the only good pic I could find online of a Roanoke unit.
A good friend and I were given the task of figuring out some way to power the head independently. We came up with a Cat 3208 powered unit the would mount to the pivot ball at the front and the turntable mounts at the rear under the gooseneck of the grader, needless to say it was a beast. We ended up making 5± units over the span of a couple of years, unfortunately I didn't take one pic which ticks me off.
Reason for my posting this is that I had hear of two instances where the blade had come off the machine and one had gone thru a car door in a driveway, the other had stuck in a house when it came off. I couldn't imagine the centrifugal force on the blade, the thing weighed over 20 lbs I'm sure.
Scariest part of the whole build was checking the head speed with no load. I got elected to stand on the head holding a tach up near the coupling under the motor mount with these blades whizzing around under you, mind you, it was the safest place to be.
Stupidest thing I ever did was taking the first one out for a test cut on a back, untraveled (much) road. I had never operated a grader before but being young and stupid figured it couldn't be that hard...right, you're just driving on the shoulder? Cutting roadside brush on this road all you could hear was the 3208 roaring, the head screaming and the grader engine. I never noticed a guy wire for a light pole...that was till I hit it, even then all I remember was hearing a wierd "twang' noise. we got back to the shop and my buddy who was driving the pickup behind me asked if I had seen the guy wire go. "what wire" I asked him. We went back and looked, the guy wire was looped over the horizontal wire on the pole which was thankfully not a power pole but telephone only for someone who lived way back in the road. Fun times...when you're young and don't know any better.
/ Bush Hog repair question #40
I've never lost a blade but I have been hit in the back of the leg by stuff flung by the blades. Yes I do have safety chains. And you wouldn't think a small stone could get past the chains, lift arms. axle, controls and pinch me in the calf. I doubt a sniper could make that shot. As I've said before the closest I came to serious injury was a rock that hit my seat back. Luckily my tractor has a highback suspension seat that saved me. Good size dent there.
Never underestimate what can happen when something is moving at those velocities.
Bounce here, bing there, ricochet there and you've got shish kabob (shish roustabout).
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
New Carbon Steel 4.75-12T Shackles, 38 Total (A62679)
New Carbon Steel...
Ford Golden Jubilee Tractor (A66285)
Ford Golden...
Case CX75C (A62177)
Case CX75C (A62177)
For Sale - Brush Hog - Woods RCC42 rotary cutter
For Sale - Brush...
Wilmar Wrangler 4500 Loader (A66285)
Wilmar Wrangler...
