lilranch2001
Super Member
- Joined
- Nov 25, 2009
- Messages
- 9,123
- Tractor
- Bobcat CT 235
It seems to me that since you paid for a highly strengthened glulam, then anything less that they would give you back is ripping you off……
depends on what material the block was made from actually.So you are saying that you would accept a welded block on a new truck??
That's interesting example. Very visual, too. It becomes pretty intuitive that a stack of laths will bend easier than a solid beam the same size, but how about shearing strength? Did that change as well?Two smaller beams are weaker than one large beam. The bending strength of a beam depends on the depth of the beam, and slicing it lengthwise only weakens it. Look at an extreme case where you slice the beam into 3/8" lath thicknesses. It would hold up very little.
They pay for, labor, epoxy, lag bolts, possible sister, and the original cost of the beam. With a contract that the beam will not fail as repaired. I don't see that big of a problem with this beam. It seems a bit over engineered in the first place. What was the building spec for this? Is it decorative, to be so large? Other wise, you'll probably have to sue, and get nothing.
The engineered joists ("I-joists") are less likely to warp or change dimension compared to a 2by, but they are engineered to be the same strength, which is a lot in the vertical, and not so much horizontally. That makes the great for floors, where almost all of the load is vertical.My beams in the basement supporting the 36ft long floor trusses, have a cross section made from osb type material. Of the same sizes, is the 2x glulam stronger than the osb beam, or other way around? Just wondering. Jon
A beam will have differnet compression/tension points depending on where the load is. You can't unphysics that. The beam will act very different depending on if the load is on the center or the two sides.No, LD1 is correct. Any beam simply supported like this is ALWAYS in tension on the bottom and compression on the top, even just from its own weight. Of course the applied load will be far greater than the weight, but it does not matter if the load is directly in the center as you noted, or distributed (which is most common).
I have a giant glulam in my great room that spans like 30' and it has never cracked the slightest bit. It sounds like from the OPs last post that they are beyond investigating and actually planning to make repairs which is good. This does not look like anything I would let go, IMO.
Here is my glulam beam. Before finishing and after
View attachment 813447View attachment 813448
But how many beams are put up without a concern to load types?
When I last checked, the recommended uses for the I-joists, the OSB versions;@ponytug, clarification. Floor joists are engineered I joists from a v4eetical OSB with flnges of 2x material. Those are held up by a 5.5" wide x 11.75" tall LVL. That LVL is made of 11.75" vertical strips of plywood, not OSB (my mistake on earlier post). My question is the OP's glulam or my LVL for the same dimensions stronger?View attachment 813688View attachment 813689
That's a good looking structure, it's got some style to it.The Anaheim ice center went over budget on steel beams and was redesigned for wood;
There is something about hockey / ice arenas that seems to bring it out. My favorite is probably Yale's Ingalls rink;That's a good looking structure, it's got some style to it.
I am gonna say in this case....the LVL is probably stronger.@ponytug, clarification. Floor joists are engineered I joists from a v4eetical OSB with flnges of 2x material. Those are held up by a 5.5" wide x 11.75" tall LVL. That LVL is made of 11.75" vertical strips of plywood, not OSB (my mistake on earlier post). My question is the OP's glulam or my LVL for the same dimensions stronger?View attachment 813688View attachment 813689
I think most everyone is over reacting. That doesn't mean I wouldn't follow through with the manufacturer checking it out. But I doubt it is anything more than a cosmetic problem that can be easily remedied. Lags in the bottom would bring it up to its original design strength characteristics and the lags could be covered to make them un-noticable. I suspect that gluelam has a incredibly large safety factor. Replacing it would be overkill and far worse than leaving it alone or repairing it.
