Kubota L2800
/ Kubota L2800 #1
lkwashburn
Newnan, GA
Kubota L2800
I have a 2010 Kubota L2800 4WD. It is currently equipped with Agriculture tires. I would really like to convert to Turf Tires.
I’ve attached the tire spec for the tractor.
My question is; will I need to get new rims to accommodate the turf tires or can I get turf tires that will fit the existing rims. I assume the size is critical since it is 4WD.
Not very knowledgable about this stuff, any help (including sources) would be greatly appreciated!
/ Kubota L2800 #4
And when you run all the numbers, it's not worth it. You would be better off selling the tractor with the ag tires and buying another. Or, better is to keep what you have and buy a second tractor with turf tires and call it good. :)
/ Kubota L2800 #5
You might be able to find a used set at a dealer or private owner.
/ Kubota L2800 #6
If your going to run rear tire chains you may need spacers.
/ Kubota L2800 #7
My uncle is looking to get tire chains for his L2800 project. Any idea about the size of spacers it needs? We'll work on it once we mounted the suspension and off road tires on the Wrangler this week.
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A63276)
2017 FORD F-350 XL...
John Deere Decorative Metal Sign (A61569)
John Deere...
2025 Pabreak Hydraulic Vibratory Plate Compactor Skid Steer Attachment (A61567)
2025 Pabreak...
2005 Ford Excursion 4x4 SUV (A60352)
2005 Ford...
New/Unused Landhonor Air Impact Wrench (A61166)
New/Unused...
