Kubota L2800
   / Kubota L2800 #1
lkwashburn
Newnan, GA
Kubota L2800
I have a 2010 Kubota L2800 4WD. It is currently equipped with Agriculture tires. I would really like to convert to Turf Tires.
I’ve attached the tire spec for the tractor.
My question is; will I need to get new rims to accommodate the turf tires or can I get turf tires that will fit the existing rims. I assume the size is critical since it is 4WD.
Not very knowledgable about this stuff, any help (including sources) would be greatly appreciated!
   / Kubota L2800 #4
And when you run all the numbers, it's not worth it. You would be better off selling the tractor with the ag tires and buying another. Or, better is to keep what you have and buy a second tractor with turf tires and call it good. :)
   / Kubota L2800 #5
You might be able to find a used set at a dealer or private owner.
   / Kubota L2800 #6
If your going to run rear tire chains you may need spacers.
   / Kubota L2800 #7
My uncle is looking to get tire chains for his L2800 project. Any idea about the size of spacers it needs? We'll work on it once we mounted the suspension and off road tires on the Wrangler this week.
2023 Load Trailer (A55787)
2023 Load Trailer...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
2011 New Holland B95B Cab MFWD Loader Backhoe (A55314)
2011 New Holland...
2008 Ford Focus SEL Sedan (A54815)
2008 Ford Focus...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A51691)
2024 Wanco...
2013 Ford F-150 Pickup Truck (A53422)
2013 Ford F-150...
