Workmaster 25S Blows Sol/Inst/PTO Fuse
   / Workmaster 25S Blows Sol/Inst/PTO Fuse #1
Papi-17
New Holland 25S
Working all day with no issues until my Workmaster 25 suddenly died. The starter cranked but would not turn over. Thought I ran out of gas but found the Sol/Inst/Pto 10amp blown. Replaced the fuse, the tractor started but blew the fuse again after only a couple minutes of operation. Replaced again - the same scenario. After the 3rd replacement, it only ran a few seconds before blowing the fuse. On the 4th fuse, it blew within seconds of turning the ignition key to the on position. It would appear to be a hard short that I need to troubleshoot but don't have an electrical diagram. I am open to any other advice or checkpoints that may cause this fuse to blow.
   / Workmaster 25S Blows Sol/Inst/PTO Fuse #2
I'm having the same issue replaced shut off soliend and still popping main 30 amp fuse n 10amp fuse for sol/inst/pto what else could I do to fix this problem it's a new holland 25s workmaster
   / Workmaster 25S Blows Sol/Inst/PTO Fuse #3
Something is shorting to ground to pop fuses. Or drawing too much amperage. Typically relay or solenoid will be culprit on drawing excessive amperage. Find your schematic and start looking for amp draw. If you had Flir infrared camera you spot the heat draw. Otherwise use an amp meter to find draw. Nothing found look for short to ground on the circuit. Hot bare wire making intermediate contact usually will show carbon marks.
   / Workmaster 25S Blows Sol/Inst/PTO Fuse #4
This was for the LS MT125, but it is the same tractor (LS builds the NH 25s for them). Probably the same solenoid causing the issue.
   / Workmaster 25S Blows Sol/Inst/PTO Fuse #5
   / Workmaster 25S Blows Sol/Inst/PTO Fuse #6
I was searching the internet and found this related to the issue I just started to have. 25s running fine then just shuts off. Took me 5 10Amp fuses to find what it was but found that my seat sensor wire was got squeezed between the seat the last time I used the backhoe. Hope this helps anyone still trying looking for answer that could be related to this.
   / Workmaster 25S Blows Sol/Inst/PTO Fuse #7
What did you find it to be that causes the fuse to blow
   / Workmaster 25S Blows Sol/Inst/PTO Fuse #8
What did you find the issue to be
2014 RAM 2500 (INOPERABLE) (A58214)
2014 RAM 2500...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
Caterpillar 262C Compact Wheel Loader Skid Steer (A59228)
Caterpillar 262C...
2006 GMC C5500 BUCKET /SIGN TRUCK (A59575)
2006 GMC C5500...
