Show your fire extinguisher
/ Show your fire extinguisher #42
Amazon or eBay. Amazon prices can change quite a bit over time.
Amazon seems to use an interest-based pricing model. Revisit a single item multiple times from multiple locations, and you'll sometimes see the price increase over a few days. Not enough to really matter, it's usually just a few pennies or percent, but interesting to watch, nonetheless. Don't revisit that item for a few weeks, or check on a seasonal item you had bought previously that is now out of season, and you can sometimes see the reverse effect.
/ Show your fire extinguisher #43
Smokeydog, I sure like the bracket you show - where can I find one like that? I've only seen the flimsy ones that usually come with the extinguisher, and are next to impossible to mount to the tractor. I'd get a couple of those if I could find them! Thanks, Greg
I got one just like it from my neighbors son, who works for a fire extinguisher repair company.
Is there one near you?
/ Show your fire extinguisher #45
Sure can. See below >
I did some rough terrain mowing and it held rock steady. So far so good.
Thanks for the info, it does fit well.
/ Show your fire extinguisher #46
I have 2.5 and 5 pound ABC dry chemical units and just recently had a couple of them hydro tested and refilled. I will ad that all of my extinguishers at this time are AMEREX. Not badger not kidde, 'nada. At risk of a ford and chevy contest, Amerex has better guts. I serviced many brands decades ago and believe what I say is true to this day. Previous to then, I ran General'. You will never gripe about what you paid for any unit once you need it.! I buy mine locally and have them serviced the same. If you have a big enough outfit, a local extinguisher company can put you on their list, come out now and then and do an update tag on your extinguishers. You insurance agent loves to see that kind of detail.
/ Show your fire extinguisher #47
...all of my extinguishers at this time are AMEREX... Previous to then, I ran General'.
These two brands make up at least 10 of my dozen-odd extinguishers, as well. Although Badger does also make professional serviceable extinguishers, or at least they did in 1998. Here's the one hanging in my basement stairway:
/ Show your fire extinguisher #48
Are there any one that knows what PURPLE K is use for?
willy
/ Show your fire extinguisher #50
The Navy uses them for chopper crashes magnesium was only able
to extinguish the fires with Purple K as water makes mag burn hotter and faster and if possible would just push the chopper over the side
if possible.
willy
Did some mowing yesterday. If one extinguisher is good - two is better.
/ Show your fire extinguisher #53
PKP is standard on aircraft carriers along with liquid foam. Nasty stuff that works when it should. Don't leave port with out it.
I used to keep a Purple K in my truck; it left the Army with me, but I don't believe it survived my accident last year.
/ Show your fire extinguisher #56
Been studying this thread. Some good information.
I’m trying to figure out where to mount. I’m considering mounting a Kidde mount on the right rear fender, which is on the side where the loader stick/hoses are located, so it won’t interfere with mounting/dismounting the tractor seat. I don’t want to mount on ROPS and limit view, nor behind seat as space is limited as I’m long legged.
Has anyone done this? Downside to mounting on fender? thanks!
/ Show your fire extinguisher #57
No pic handy, but I hose clamped the mounts for a marine type extinguisher to my ROPS nice and low. No vibration.
Never got in my way ...
/ Show your fire extinguisher #59
I have looked at my tractor closer and believe I can use a 1lb ABC and some 3” pvc to mount behind my seat. Section out the pvc and simply drop the canister into it. Simple.
2014 FVCG TRAILER (A61567)
2014 FVCG TRAILER...
2022 EZ-GO ELITE...
Fork Extensions (A61572)
Fork Extensions...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
iDrive TDS-2010H...
2023 CASE TV450B SKID STEER (A64279)
2023 CASE TV450B...
