Well.... OUCH!
/ Well.... OUCH! #1
WranglerX
Super Member
A Little Bit West Of Yosemite NP
MF GC1715
Did the unforgivable.... While working brush, I manage to poke a branch (I guess) up under my GC1715.... Unknown to me it bent a hydraulic line up against the drive shaft and drive shaft actually ground through the steel hydraulic line.... First clue was a trail of oil drops across the ground.... And yes its going to be a nasty job to fix... After looking at it its going to take removal of floor boards, ROPS, seat, and fender assembly.... Tractor is now sitting at dealer waiting repair estimate, after looking at it all weekend needed repair job is just to much for me..... Besides it was due for its next 250 hour hydraulics(HST) and front axle oil/fluid changes....
Yes there is a hose clamp on line, and yes there is a piece of rubber under clamp over hole in line, no its not a permeant fix, but it did slow the flow a lot so I could move it around and load it on trailer....And no the after market hydraulic filter guard would probably not have protected hydraulic line.... I guess moral of story is maybe one should inspect underside of tractor more often....
/ Well.... OUCH! #2
Not an issue with either of my Kubota M's. The only item 'hanging down' is the fuel line cross over for the saddle tanks and it runs inside a metal shield. Everything else is up between the frame rails.
/ Well.... OUCH! #3
Bummer. Any plans to skid plate it after repairs are made?
/ Well.... OUCH! #4
Massey Ferguson GC1715 Dimensions​
Massey Ferguson GC1715 tractor photo
2013 - 2018
GC1700 Series
Sub-Compact Utility tractor
Shiping weight:1433 lbs
650 kg
Ground clearance:6.7 inches
Subcompact tractors are designed to be operated over smooth, flat, clear ground. Working brush is inappropriate for any subcompact tractor that you want to keep out of the shop.
/ Well.... OUCH! #6
Since I work mostly in the woods and on uneven ground I am glad my subcompact can't read.
Hope the bill isn't too bad Wrangler, just a bad location for that line without a shield.
Will need to check mine, not sure if my shield covers that line.
/ Well.... OUCH!
Well its good for you but hydraulic line on the MF is also up between the rails (about 3 inches above rail bottom) but when you poke the end of a stick up between the rails.....
/ Well.... OUCH!
2013 - 2018
GC1700 Series
650 kg
Actually stick has to go up about 14-16 inches to get hydraulic line, the 6.7 inches is not real, mine has more room under it than that...
/ Well.... OUCH! #11
Well that is ok s for you but hydraulic line in the MF is also up between the rails (about 3 inches) but you poke the end of a stick up between the rails.....
Have at least 12" of clearance between the ground and the bottom of my tractors and I don't make a habit of driving in the pucker bush either... Having said that both of mine have metal protective plates between the front axle and the oil pans from the factory.. I have worn the paint off the bottom of the oil pan from cutting hay.
/ Well.... OUCH! #12
My tractor came from the dealer with a custom built skid plate, glad it’s there but when working in brush there is no guarantee something won’t manage to get in where it’s not supposed to and cause problems.
/ Well.... OUCH! #13
A big stiff poker branch can really tear $ome $tuff up in a hurry. Sometime they can even rip a track off a CTL. Fix it and just be more careful in the future is all you can do.
/ Well.... OUCH! #14
Jt’s already at the dealer so it’s a moot point but from here it sure looks like you could splice in a union And a ew piece of tuning somewhere on either side of the leak. Maybe not pretty but not expensive either. But you are likely better off taking the route you did.
/ Well.... OUCH! #15
I hear you. My machine has ZERO exposed components under it. All plate steel front to back....
EXCEPT! (there's always an except!) there are a few 1" drain holes and a hole to get to the oil drain plug. Several times a stick has come up through that 1" hole in the footwell and stabbed me in the leg! Ouch! The chances are pretty slim, but if there's a way, it can happen. 🙃
/ Well.... OUCH! #16
Yup break down do suck,but what worse break down farthest point or in mud etc.
/ Well.... OUCH! #18
2013 - 2018
GC1700 Series
650 kg
Lol……wtf
/ Well.... OUCH! #19
That's the most ridiculous comment I've seen today. My opinion is all tractors are not made for clearing land but they are ALL made for running a bush hog. We all know the consequences of bush hogging and accept them, OP included but a tractor is made to do tractor stuff.
/ Well.... OUCH! #20
Yep!.... Lookin for plate and bracket material while tractor is in shop, probably first project with it when it gets home....
mines till in box but...unlike others this is ventilated for airflow
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
2013 CHEVROLET 2500 HD (INOPERABLE) (A65643)
2013 CHEVROLET...
2020 FORD F-350 (A65643)
2020 FORD F-350...
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
CAT 215CLC Excavator (A66285)
CAT 215CLC...
2004 GMC Sierra Pickup Truck, VIN # 1GTHK23U24F110736 (A65563)
2004 GMC Sierra...
