Well.... OUCH!
/ Well.... OUCH!
mines till in box but...unlike others this is ventilated for airflow
Will have to look at tractor when it comes back from shop to see if "Sentinel" actually comes forward enough to protect hydraulic lines....
From the web site and pictures of plate for GC1715 it does not come forward enough to actually protect hydraulic lines where damage occurred on my tractor.... See Large arrow.... Two smaller arrows are also hydraulic lines...
/ Well.... OUCH! #22
I did wonder about impact points but due to some medical issues was not able to dig into it. anyways you seem to be on top of it.
/ Well.... OUCH! #23
Massey Ferguson GC1715 Dimensions​
Massey Ferguson GC1715 tractor photo
2013 - 2018
GC1700 Series
Sub-Compact Utility tractor
Shiping weight:1433 lbs
650 kg
Ground clearance:6.7 inches
Subcompact tractors are designed to be operated over smooth, flat, clear ground. Working brush is inappropriate for any subcompact tractor that you want to keep out of the shop.
Good example of buy more than you need when buying a tractor. You will never be doing something and at the same time crying 'it is too big, it is too big'.
/ Well.... OUCH! #24
My subcompact fits through the wood trails and between the trees and garage.
Anything bigger wouldn't, right tool for the job, if I had more open land and less woods, bigger would be needed.
/ Well.... OUCH! #25
Murphy is alive and well. And he's fully prepared to surprise you when you least expect him to.
Chance is bad enough, but combined with my native stupidity I'm amazed the tractor has survived this long. The only reason I'm still here is that the good Lord requires a bad example for others not to follow.
I use my tractor in the woods exclusively and I've had a couple of gotchas. one was a vine climbing a tree was rolled over by my rear tire and slammed the mirror against the cab like a gunshot throwing glass everywhere. Another was a stump bending my step back into my rear tire between the threads. It didn't stop anything, but sure sounded & felt like it should.
I'm sure all tractors would be best operated on nice level flat ground free of rocks and other hazards, but that ain't what I got mine for.
/ Well.... OUCH! #26
My philosophy is.. If you want to 'romp' in the woods with a tractor, buy a large enough tractor that one, has the ground clearance and two, has the suds to handle that. Sub compact and compact tractors might be good for around the house operations and mowing the lawn, but certainly aren't suitable for romping in the woods.
/ Well.... OUCH! #27
Tell that to my tractor, as it spends 50% of it's time out there moving tree trunks, branches and flailing trails. Only 2 of my 6 acres is open land.
/ Well.... OUCH!
Same here... Never though in the 5 years I have had tractor it would be put to the test than this last winters snow storm did to property....And anything bigger would spend more time in shed because its to big for access to about 50% of property... Besides this is a first in about 350 hours of operation and sort of random.......
/ Well.... OUCH!
But I can put my 52 inch wide tractor between two trees 54 inches apart, can bigger tractors do that?
/ Well.... OUCH! #30
...and when you fock it up, don't whine about it. Solution, cut one tree down and use it for firewood. I own a woodlot myself but I don't drive my tractors in it. If I have to remove a culled tree, I'll winch it out.
/ Well.... OUCH!
You sound like the guy who takes a 16ft 6in load under a 15ft 6in overpass....
Also this last winters storm which dropped at least 24 inches of snow, when we usually get 3-4 inches, storm dropped about 30% of my trees and created 40-50 widow makers in others, has cost me at least $18,000 in having a crew in for cleanup ( approx. 10 days) that I could have never done even with bigger tractor in reasonable amount of time, this took care of about 3 acres and now I have about 4 more acres to clear on back property....And all in all I will probably have 7-8 cords of wood to actual give away (to needy families) because I will never use it all and its a shame to just let it sit and rot.... And no I don't need any ****** intellect remarks from you because you are not onsite supervisor...
/ Well.... OUCH! #32
Why do you keep in with this
I as well as many others here can disprove it exponentially…..
/ Well.... OUCH! #33
Big tractor can't romp in the woods because the trees are too close together.
Solution: Cut down the trees so it can fit. :rolleyes:
I had a large cabbed tractor loader. One of the primary reasons I got rid of it is because my little PT425 can go places the IH2500b could not.
42" wheel width. Not only can I romp in the woods in virtually any place I want without damaging/clearing trees, I can disconnect the 60" mower, pick it up from the side with the forks, and drive it through a 48" gate and mow or brush cut on the other side.
/ Well.... OUCH!
Well got it back from dealers shop..... $37.99 in parts and $1100 in labor..... They had to remove ROPS, seat and back fender and floor board assembly's to just get to tube to replace it.... One expensive poke of a stick...
/ Well.... OUCH! #35
I am looking at a similar labor intensive tear down over two $39 seals going bad on a 770 hour Mahindra.
Tractors are fantastic until you run into an expensive repair.
I can’t believe how tractor makers put hydraulic lines and filters under tractors without any shielding.
2024 JCB 35Z (A60462)
2022 John Deere 5055E (A64126)
2022 John Deere...
NEW Wolverine GB-11-72W Skid Steer Grapple Bucket (A62679)
NEW Wolverine...
Landhonor FW-13-15000G, Skidsteer Mount Winch  (A62679)
Landhonor...
2015 John Deere 6125R (A64126)
2015 John Deere...
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
