MX6000 Air Conditioning
/ MX6000 Air Conditioning #21
You need to take the roof off to access the ac on your tractor. It’s not hard. Look on the parts breakdown to identify which screws to remove it.
Actually, pretty easy to ascertain which screws need to be removed. Just unscrew one and if it's long, those are the ones to remove, if it's short, put it back in because those are the ones that secure the headliner to the ROPS frame. It will be every other long screw.
One thing to keep in mind and that is, you'll probably have to replace the perimeter gasket because when the roof is in place, it compresses it and it won't expand again. I replaced mine the first time, I believe the gasket then (with the corner pieces) was around 100 bucks and it's a dealer (Kubota part) item.
The other issue you may have is the OEM Riv-Nuts in the roof may be loose. I replaced them as well with new ones plus I 'glassed' them in for added strength.
Finally, you won't be able to remove the blower or blower housing without breaking out the AC evaporator and the heater heat exchanger is easy, the evaporator isn't. You would have to remove it which means you would have to recharge the ac system and add PAG oil.
What I did was I loosened the top blower housing and propped it up with a wood block which allowed me access to the evaporator and heater coil and I used a handheld pump sprayer with diluted Purple Power and soaked them down and then used clear water to rinse them out and flush the debris down the pan (underneath) which also flushes out the drain tubes. I rinsed it until the discharge water (from the drain tubes was clear.
Like I said, I did a thread on here or on OTT detailing the procedure. I clean mine every spring now. My seed house buddy down the road with his big JD's does the same thing every year.
When you take the top off, remove the outside filter and take a hard look at the gasket. I replace mine every year as well. If the gasket don't seal the filter completely, dirt will get in pretty quick. I used closed cell expandable foam with adhesive on one side to replace mine. Any box store will have it as well as the Reflectix.
/ MX6000 Air Conditioning #23
2nd on the rivnuts my last one at the back I was in a hurry and cross threaded. It spins so I had to take off filter and hold it with vice grips while I threaded it in. I’ll epoxy them next time roof is off. Taking it off is ok but putting those long bolts in and getting them started was a PITA.
Then I went a step further and torqued to factory specs. I think I used 34 inch lbs.
Good luck.
/ MX6000 Air Conditioning #24
I'm on the fence with the new design with everything under the seat because to get to anything you have to remove the seat first.
/ MX6000 Air Conditioning #25
Use fiberglass mat and liquid instead. HF sells a nice Riv-Nut setter (Doyle) with an assortment of them included and you can use it to tighten the existing ones if they spin. Kubota should have used metal backers (washers) under them but didn't except on the 2 on the front.
/ MX6000 Air Conditioning #26
My MX5400 cab requires cleaning of all coolers and screens about every 3-4 hours while bush hogging or running the lane shark.
The radiator genie is what I use, well worth the money.
I'm in SC and have no tint on the glass.
My tint guy doesn't really want to do it due to all the parts needing to be removed. Sounds like it will be expensive. Then I'd want the 3560 done too.
/ MX6000 Air Conditioning #27
A radiator Genie is way overkill for a roof air unit and will probably compromise the electrical components up there.
I use one for my under hood HX's but that is it.
All Kubota cab models come with tinted glass from the factory btw.
/ MX6000 Air Conditioning #28
Should have clarified- I'm speaking of under the hood coolers.
I'm aware there is some level of tint to the factory glass.
So, I'll excuse myself and you can pick someone else's post apart.
/ MX6000 Air Conditioning #29
Yep. It is up there temp wise. And I am breaking a sweat in the cab.. and I am not in full sun all the time. Just does not feel cold coming out of the vents...and the water dripping down the right side window tells me something is plugged....
Stick a thermometer in the air stream as close to the fan coil as possible. If it is 55 to 60 degrees it's doing all it can. Remember that heat goes to cold so mother nature trying to heat that air up as fast as possible. You probably have more heat coming in than your rig can handle.
Well, others have said they can get frigid in their tractors. And, two other things, the first year I had this machine, I don't recall breaking a sweat, ever. The other thing, I have water coming down the glass, and wife reported the right side headliner, upper right back, is wet. Something is not draining right.
Looking at the drains, left side is dripping at a greater rate than right side. A much noticeable rate.
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2018 FORD TRANSIT 350 SERVICE VAN (A59823)
2018 FORD TRANSIT...
SCAN TO RECEIVE TEXT UPDATES (A62129)
SCAN TO RECEIVE...
iDrive TDS-2010H...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
