/ Argon gas supply for aluminum MIG
Maybe when he needs soda cans stuck together he can call you?Not a lot of MIG users could do this.
I really only use a MIG for Aluminum for production. Small jobs are almost always easier with the much more versatile TIG.
With a TIG, you can sit there adding heat without material until the part is where it needs to be. Being new to welding aluminum and starting with a MIG, seems like the best way to avoid aluminum altogether, after the first few attempts.
It gets even worse if you need to repair thin aluminum. Not a lot of MIG users could do this.
You have to pay to play, it's as simple as that.I'm getting set up to be able to weld aluminum. I have a Hobart 210 MVP and recently scored a deal on an SpoolRunner 100 gun. I know that I need to use Argon 100% for aluminum instead of the 75/25 Argon/CO2 I use with steel MIG.
Question is: Is there another way to get a small supply of argon other than buying a cylinder from my local welding supply place? They want $225 to buy a 40cf (almost the smallest tank). Even the tiny 20cf is $140.
I probably will be doing very little aluminum welding and I'm hoping to get into it cheaper than that. If this is the only reasonable way I guess I'll suck it up and lay out the cash, but looking for alternatives here first.
Thanks.
So if you can't afford or don't want to afford to pay the gouged maximum price, just sell your stuff? What a weird thing to say to someone. I just bought a OEM fuel selector valve for my 7.3 Powerstroke. One site had them for $350 another had them for $230 for the same Ford OEM valve. Should I sell my truck now because I bought the $230 valve?You have to pay to play, it's as simple as that.
Don't take up expensive hobbies. Sell the equipment if you can't afford the toys. First world problem.
For someone who only does occasional aluminum welding, renting or leasing the bottle can end up being expensive. For someone who wants to give aluminum welding a try, it makes even less sense. At least with the purchase of the bottle, the O/P has a chance to recoup some of his investment.Is there no one in your area that rents tanks out, or do they all have to be owner tanks?
