tacticalturnip
Super Member
You're arguing over which multinational megacorporation panders the most to your sense of patriotism like it has any validity in towing.
BTW check out this video:I looked it up:
2022 Toyota Tundra TRD Pro CrewMax 4X4
0-60 mph 5.7
Wow - they are really slow....![]()
The workers at the Huntsville plant have rejected unions believing they are treated better than union workers. As a result the Huntsville engine plant is the only Toyota plant in the world to build 4, 6, and 8 cylinder engines. It didn't start that way. And recently there is a joint venture with Mazda to build complete automobiles a few miles west of the Toyota engine plant.While they are mostly made in America, both locations listed are non-union states. Don't know enough to say where net profits go.
I would suggest only the 5.7 motor if you are going to tow. If you choose another truck do not get the 10 speed transmission.
I agree with your half ton thought.10k is too much weight behind a half ton for any sort of frequency.
A 6,000lb boat behind a 2020 F150 Crew Cab V8 4x4 was a white knuckle ride when traffic slows suddenly on the highway, just not enough weight and stability. Plenty of power, trans would shift about every 7 seconds (10 spd) you get used to manually mode to prevent that.
16’ enclosed (7k gross) in a heavy cross wind is unnerving with an empty bed on the truck. Trailer is in control.
So it is emotional rather than rational.I don't care why Toyota chose the boosted V6 route. I will say that I'll take a boosted V6 Toyota as a V8 replacement over a Ford/Chevy that uses a turbo V6 as a V8 replacement. I have no emotional connection to V8's in Japanese vehicles like I do with American OEM's in their trucks and muscle cars.
