Towing 10.1K with either Toyota Tundra SR5 OR F150 which is better?
Status
Not open for further replies.
   / Towing 10.1K with either Toyota Tundra SR5 OR F150 which is better? #31
I think most of the newer 3/4 ton and 1 ton trucks have a Class V hitch on the back, which usually ups the tow capacity and hitch weight a little over 10,000 pounds and throws out the need for a WDH. I had a 2004 3/4 ton Dodge Ram and it had the 5000 pound trailer 500 pound hitch weight restriction needing a WDH above those weights. That was pretty common on those older trucks.
   / Towing 10.1K with either Toyota Tundra SR5 OR F150 which is better? #32
Agreed, on the 3/4 and 1-ton trucks. But OP is only looking at 1/2 ton, so they'll likely be requiring a WDH.
   / Towing 10.1K with either Toyota Tundra SR5 OR F150 which is better? #33
If you really mean "on the bumper", then I guess I could believe that 500 lb. is just the tongue weight rating of the bumper itself, which seems reasonable. But if you mean on a proper hitch receiver, then I'd be surprised if any 3/4 ton configuration in a given brand doesn't have a much higher tongue weight rating than the 1/2 ton configuration of the same brand.
Manufacturers vary tow rating according to engine, drivetrain and brake configuration, but they all top out at a maximum of 10x tongue weight rating. You could say it's optimistic to assume anyone could manage to load a trailer for a perfect min. limit 10% tongue weight, but at least it's a consistent rating method for comparison.
I mean on the factory 2" Class IV receiver hitch. Trailer over 5000 lb required WD hitch. Ford limited F250 & F350 to 10,000 bumper pull with WD hitch for 2000 model year.
   / Towing 10.1K with either Toyota Tundra SR5 OR F150 which is better? #34
Looking at those numbers from 20 years back, much of it's within the range of a modern half-ton.
In turn, the numbers on a modern heavy-duty pickup are even higher.
Here are the ratings for the 2019 Super Duty.
   / Towing 10.1K with either Toyota Tundra SR5 OR F150 which is better? #35
Exactly. Current 1/2 ton does what you used to traditionally need a HD pick up to do.
   / Towing 10.1K with either Toyota Tundra SR5 OR F150 which is better? #36
Whatever you decide to buy, make sure you check the yellow and white load sticker for the actual payload of your actual truck before you buy it. The payload number may be lower than you're expecting if all you look at are the published towing capacity sheets.
   / Towing 10.1K with either Toyota Tundra SR5 OR F150 which is better? #37
On paper, yes.
But I feel sorry for those who actually believe the largely bogus J2807 tow ratings, that emphasize speed up grades and acceleration over what counts in real life.
To me, the longer the wheelbase and the heavier the tow vehicle the better. And that's after having completely given up on bumper pull trailers.
   / Towing 10.1K with either Toyota Tundra SR5 OR F150 which is better? #38
These trucks are coming with more computer aided towing assists than I even understand, combine that with these 8 and 10 speed transmissions, and special brake and axle ratios in these towing packages- these trucks are a lot more capable than any half-ton available just a decade ago. I understand not believing the capabilities of these trucks, but we live in such a litigious society I imagine the manufacturers are publishing numbers that cover their arses.
I mean, I'm just a layman, but 8-10k seems quite reasonable for a modern half-ton. Hell, my wife's Kia Sorento can comfortably tow 5k lbs. Now I wouldn't dare go over that, but it's a lot of weight for a glorified station wagon.
   / Towing 10.1K with either Toyota Tundra SR5 OR F150 which is better? #39
High tow ratings sells pickups, that's the bottom line for them.
And while I haven't been able to resist trying to tow an empty 16' bumper pull flatbed when getting new 1/2-tons, the results have been utterly predictable: There's no way not to notice that the trailer is back there, and the mileage goes to crap.
Did pull a 16' enclosed trailer about 24,000 miles per year for a while, 1,000 miles at a time, mostly with a Ram 2500. One time with an Ecoboost F150.
It pulled okay as far as power goes, but once at the destination I took a close look at the components underneath. Its rear axle, for example, was positively puny compared to the 2500's, yet the F150 had a higher tow rating. For how long would that diff last?
Also, the 5.7 in the 2500 got much better mileage - same route, same trailer, same weights in it. To me, 1/2-tons are cars with beds on them, and are not suitable for towing with.
   / Towing 10.1K with either Toyota Tundra SR5 OR F150 which is better? #40
I pull a 7000 lb. 16 ft tandem axle closed side trailer with my 1/2 ton. Yeah, you know it's back there and the mileage takes a hit, but otherwise no issues. I'm only doing local hauling of machinery and firewood, so not a problem on either count.
Tow vehicle has 5.7L Hemi with ZF 8HP trans 3.92 rear and factory "heavy duty" rear springs, for what it's worth. Both the 3.92 rear and the springs were special order items from Ram, but I can't imagine why anyone would ever order a truck without these two options. It also has 10-ply rated tires, as the stock tires were fine when unloaded, but got a little squirrely approaching full load.
Status
Westfield Conveyor (A56436)
Westfield Conveyor...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
White 6138 Planter (A59814)
White 6138 Planter...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
