What did you do with your Power Trac today?
   / What did you do with your Power Trac today? #341
I also purchased a new 7000# PTO winch military surplus from a Gama Goat for $250. Still in the crate. I'll probably use that on my trailer to load logs out at our property. I'll power it with a hydraulic motor/gas engine setup on the trailer, but make it usable on the PT425 as well. Might take the log splitter and make its engine/pump setup portable for the trailer. All kinds of fun.
You lucky dog! I have been looking for one for years and they haven't ever been cheap enough for me to buy.
Have fun!
Peter
   / What did you do with your Power Trac today? #342
So,...I chipped wood with the 1445 today for ninety minutes (60%-100% throttle).
  • Outside air temp 55-60F, about what it was when I measured above
  • engine oil temp 200F
  • exhaust temperature 500F, +/-, up from 390F
  • outside of muffler now 120F, down from 390F,
  • hydraulic oil 105F coming off of the oil cooler and
  • hydraulic oil 125F in the tank and oil filter.
Muffler wrap for the win!
As hot hydraulic fluids have been a pretty constant issue for me, the muffler wrap was so worth it. I think that the hydraulic oil cooler works better because it now pulls in cooler air over the muffler. I may need to do a slight adjustment of the exhaust tip angle to keep it from blowing on the tire, but no issues so far.
All the best,
Peter
   / What did you do with your Power Trac today? #344
Replacing old corral fences, aka fun with the Power-Trac post driver;
The tractor is on a narrow road perpendicular to the tractor, I.e. along the fence line, so some of the posts involved backing up the 25 degree slope to the left, which leads to some creative parking. This is the fence in the back of #330 What did you do with your Power Trac today?
All the best,
Peter
   / What did you do with your Power Trac today? #345
Looks like some very challenging terrain to work on
   / What did you do with your Power Trac today? #347
Isn't the line "Join the club, we've jackets"? Which is why I bought a 1445. The slopes on my terrain make many jobs complicated, and some things only in certain seasons, and some only with lots of preplanning.
especially when using a heavy post driver.
Definitely! When I was thinking about buying, Terry did mention to me that one unlucky owner had tipped his tractor over with the post driver on a steep slope. I have tried hard not to be owner #2.
Despite its weight, I find it easier to use on slopes than an auger because once you are at your desired location, it is much more stable, as the ground pad of the driver has as much tractor weight on it as you want. Whereas with an auger, it is just the tractor wheels, and you have to have the tractor more or less exactly on the slope line.
Driving the post driver around on slopes, I am careful to keep the driver tipped to near horizontal, but not too near, as it possible to have it fully extend out if it is pointing downhill. I also try to go up/downslopes with the driver pointing uphill, whenever possible. I don't raise it to the vertical unless the driver is moving up in the vertical plane, or close to it. With those caveats, it is a great tool. All challenges aside, the post driver works well in my heavy clay soils, as long as there is some moisture in the soil. From now through November, if I need to drive a post, I will dig a six inch deep hole the day before and add a gallon or so of water, which is enough to soften the soil. Otherwise, the poor post is between the literal rock and a hard place, and not every post survives to the subsoil with some moisture in it.
All the best,
Peter
   / What did you do with your Power Trac today? #348
Out pulling bay tree sprouts today. In prior years, I have tried pruning, and various chemical treatments to no avail.
Process: drive up to sprouts, wrap chain around suckers, pull, repeat. Usually, the engine is running, so I'm wearing ear muffs, and I'm reaching into the brush and leaf litter around stumps.
The space above the retaining wall looked like the brush in front of the PT. Lots of suckers.
The process gets surprisingly large roots out, which makes me hopeful about reducing regrowth. (No I did not cut that root, it just peeled away like that.)
SO...on my second to last pull of the day, working my way around a large stump, I pull the chain around a clump, and reach down to wrap the chain around a second time, and out from under the chain, four inches away from gloved hand, shoots out a two to two and half foot long four year old rattlesnake. 👁️👁️ :eek:
That got my heart rate up. Nothing like a rattlesnake at close quarters to get me wound up, and that is by far the closest that I have been to a rattlesnake that wasn't behind glass. For all I know, he could have been rattling for five minutes as I got closer to his hole in the stump. I haven't seen a rattlesnake move that fast before, either, so he was pretty wound up as well.
Maybe leaving the tractor running and wearing earmuffs while reaching into brush wasn't a smart plan. Note to self, new plan: remove ear protection before reaching into brush.
Now for a calming cup of tea or something...
All the best,
Peter
   / What did you do with your Power Trac today? #349
Yikes!
The most excitement I might get is a bunny! 🤣
   / What did you do with your Power Trac today? #350
I'd settle for a bunny any day!
   / What did you do with your Power Trac today? #351
I remember the basic safety rule not to put any body parts in places where I can’t see what may be lurking.
This is an instance where I would want to invest in a hydraulic tree puller.
   / What did you do with your Power Trac today? #352
The puller part is hydraulic. The hook up part wasn't.
Definitely operator error, not to be repeated by this operator. Normally, I am very careful about not putting body parts where I can't see them. I just wasn't thinking it through.
All the best,
Peter
   / What did you do with your Power Trac today? #354
   / What did you do with your Power Trac today? #355
So I made my own post hole digger. Use it to plant trees on my slope with a 30” bit. The bit would walk around so I got a chunk of all thread, removed the nose bit on the auger and added a 2 foot all thread spike with the nose bit in the all thread. Now when I am drilling on a slope the bit won’t walk.
   / What did you do with your Power Trac today? #356
All the best,
Peter
More chipping today.
When I stood next to the muffler and held out a hand, Ididn't feel any heat radiating off of it. The hydraulic oil cooler exhaust air feels warm, but not at all hot. Slightly lower temperatures compared to above, I think as a result of the material being chipped being greener and more leafy, rather than large branches, so less work for the engine. Engine oil was running about 180F.
All the best,
Peter
   / What did you do with your Power Trac today? #357
Was making hay yesterday and wife said rain was coming. She took out the 425 with the big bucket and was hauling 4 bales at a time from the field while I was fighting the baler twine. No more sisal for me. Was proud of her as she got 52 bales in before I finished baling. Then she drove the Ferguson pulling the trailer while I loaded it. I have a great wife, who now is comfortable on the little power track. Sorry, no pictures, never have my phone on me.
I needed a different tow hitch as I was cutting trees at a woodlot down the road, so needed to carry saw, oil, fuel etc and cut logs for splitting back. The factory pin didn't work with any trailer I had, so I fabricated a receiver hitch. The stop bolts are due to my PTs being slightly different with the 1460 actually has the newer style bolt on hitch, so they make up for the variables.
   / What did you do with your Power Trac today? #359
Lumber moving. I needed some boards for fencing projects, and they were too long for my truck, so I had them delivered. 18' 2x10" boards to redo a guardrail, plus new "true" ground contact pressure treated (0.31lbs/cu.ft.) 6"x6"x12' posts. Each bundle is just at the pucker point for the 1445.
One of the many challenges is that none of my gates are 16' wide, much less 18'...
I strap my lumber together to reduce warping/splitting until I can put the board up. The 0.31lb/cuft 12' beams are right at my comfort limit for lifting as they are still drying out from being pressure treated. (120lbs?)
Moving these boards through a couple of gates and down a steep slope was rather interesting, and I managed not to hit too many items, though I did break a railing trying to swivel the sixteen footers through a 12' ranch style gate with a top cross bar.
I also augered a couple of fence post holes for gate stops to hold gates open when not in use. One had rotted out because the drainage put water on the base, and I wanted a post with packed gravel to at least try to get the water away from the wood.
I'm still not wild about using an auger for fence posts. No shade on the auger; the one I have is a planetary drive and is super powerful. It chews the remains of old fence posts without slowing down. I find I only need to use it slightly above idle. My issue is that I have not developed the knack of lifting the auger up to clear the hole of loose dirt. I'm finding that it takes four or five auger/lift/dump repeats to clear a 3-4' deep hole. Any advice is most welcome.
I will admit that I am not using the auger on anything approaching flat ground.
All the best,
Peter
   / What did you do with your Power Trac today? #360
Augered post holes last summer with a normal tractor, and my experience was similar. Pulling the auger out of the hole repeatedly will clear some dirt, but found myself having to use hand clam shell diggers to get the last dirt out of the hole. That...and had to use a rock breaker on some stubborn rocks along the way. The auger did the heavy part of the job, but there was still hand work to do.
JLG 1255 Telehandler (A56438)
JLG 1255...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
TANK MANIFOLD (A58214)
2003 Land Rover Discovery 4WD SUV (A59231)
2003 Land Rover...
iDrive TDS-2010H...
