Bending top links??
/ Bending top links?? #1
DrericDO
Member
TX
Branson 7845C, NH Workmaster 75, Branson 4520C
Why do I keep bending the top link posts at the implement end??? Heavy duty ones I’ve bent….light duty ones I’ve bent…??? What am I doing wrong? It’s not hitting anything. Most of the time it bends using my Cabela’s 6 ft seed drill. Should I be attached the top link when the implements are in the raised position or in the down position?? What I have been doing is attaching the top link to the middle hole or top hole with the implement on the ground. Always bends at the implement end of the top link??
/ Bending top links?? #2
Does the seed drill have the slot for the top link to attach to? That slot is so the top link will float instead of being compressed and bent.
Yea it has holes and a slot. Been putting it in the hole. Should it be in the slot??
/ Bending top links?? #4
Never had that happen, but I wonder if you need to raise your ground engaging implement before making sharp turn.
/ Bending top links?? #5
Might be hitting the indicated bolt when the implement is fully lifted.
I did the same once upon a time. Turned the end over and did it again carefully to straighten it. Still working fine.
Bruce
/ Bending top links?? #6
Bruce
Yeah...I was just going to ask the same question about the indicated bolt and pinch point.
/ Bending top links?? #7
In this video, they are using the hole forward of the one the OP is using so it might not bind in the full up position. Go to about :50 in the video
/ Bending top links?? #8
Both times I've ran into that problem the solution was attaching tractor end lower and/or implement end higher.
/ Bending top links?? #9
Like said above, you're bending it on that bolt in the full lift position, either switch to the slot so it can float on the ground instead of being a fixed angle or move to the further forward hole.
I guess that’s a possibility what happened….I’ll have to look at it closer
I definitely do the raising before turning thing as I learned that lesson already the hard way. Seems to have bent while raising
That’s what I’ll try next. Highly possible that’s what happened. Thanks for the insight
/ Bending top links?? #13
I bent the whole 3 point hitch frame hitting a rock with a v plow. Also hit a hidden rock with a plow that almost left me on the hood of my Massey. Surprised it never ripped the lift arms off the tractor.
Done countless hours of 3 pth work, never bent a top link. Curious to find what it was/is.
Y’all are a smart group. Made it back to the farm and looked at the seeder. I think the culprit was the bolt. See how it is a bit misshaped by the top link pushing on it. Bad design as the mounting holes are to close to that bolt. I may need to do some reengineering! Thanks all for the help!
/ Bending top links?? #16
Where is your ROPS? With ROPS fully down, it will bend the top link.
/ Bending top links?? #17
That "bolt" and bushing are for the top hook on a quick hitch. Move that to one of the holes that's out of your way if you aren't planning to use a QH.
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
2012 GMC SAVANA VAN (A67714)
2012 GMC SAVANA...
2018 International WorkStar 7500 T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A66736)
2018 International...
2005 Sterling 9500 Truck (A66736)
2005 Sterling 9500...
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
1994 MACK CH613 FUEL AND LUBE TRUCK (A67714)
1994 MACK CH613...
