Bearing removal
/ Bearing removal #1
geoffleach1
California, Sierra foothills
Antonio Carraro TTR 4400 II, TRH 9800
I have a shredder that needs to have a bearing replaced. Said bearing is secured with a set screw. Said screw is secured using a slotted head, where the problem exists. For whatever reason, the slot is barely more than a scratch on the head of the screw.
One approach would be to drill the screw for a reverse-thread drill, but I expect that the screw is probably very hard, and the screw is not accessible.
Other approaches? Thanks.
/ Bearing removal #2
Are you sure it's a set screw?
Any possibility that it is an with eccentric lock,
Bearings with eccentric lock have a collar that you twist in one direction to grip and the other to release. Compared to bearings with a set screw, they’re easier to install, require less adjustment over time, and are better for high-speed applications. But, they only work on shafts that spin in one direction.
/ Bearing removal #3
If the screw sticks up some you can improve the slot. I've used a tiny cutoff wheel in a dremel tool to slot rounded off screw heads but a hacksaw blade would work too.
/ Bearing removal
Hmmm ... new to me, but sounds really cool!
Well, there's a hole (5mm?) with a slot-like impression at the bottom. I'm hoping that the arrival of the replacement will provide insight.
/ Bearing removal
It's buried 10mm or so in the colar. Alas.
/ Bearing removal #6
Any chances of sharing a picture with us?
/ Bearing removal #7
I just had to drill out a broken screw in a shop size nibbler. Luckily was able to get it apart enough to put the piece onto a Bridgeport milling machine. That made it easy to center drill and then bore the broken shank with a small carbide bit. Then an easy-out. But without the stability of the mill, I don't think it would have been successful. As was, it became easy. Always curious about tricky repairs & hoping for pictures...
/ Bearing removal #8
If it does have the eccentric locking collar, they will have a drilled hole to use a punch in to lock/unlock the collar.
/ Bearing removal #9
I wasted a whole lot of time years ago trying to get a set screw out of the bottom of a hole in the collar of a bearing. I just could not find the right wrench or driver to fit. Finally gave up and brought it to a friend with a machine shop and asked him to drill it out.
He put a punch in the "set screw" hole gave a couple of taps and twisted off the eccentric lock collar. Man did I feel stupid. Prior to that, I never knew such a thing existed.
/ Bearing removal
Thanks to all for the reply. I finally used a rotary tool -- one of those hand held gizmos -- this one being battery powered, with a cutting wheel to slice the race, allowing the thing to be pulled of with a bearing puller. What surprised me was what a quick job the little tool made of my problem.
2025 SDLANCH SDLC2020 High End Carport (A60352)
2025 SDLANCH...
2009 IC Corporation PB105 School Bus (A60352)
2009 IC...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2022 Lonestar T/A Dump Trailer (A60352)
2022 Lonestar T/A...
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
