DO NOT BUY SOLIDEAL TIRES. (TRIGGER WARNING)
/ DO NOT BUY SOLIDEAL TIRES. (TRIGGER WARNING)
I purchased a John Deere 21 yard cart from someone near me,,
He kept everything inside, except when used,
I bought the trailer when it was 2 or 3 years old.
The second year I had the trailer, with Carlisle tires, the tubeless tires started leaking right through the sidewall.
At the price of this cart, the tires should be able to hold air more than 5 years,,
especially considering that I also have always stored it inside,
Not what I paid, but,, this is the going price,, (Be sure to be sitting down, before you look at the price,,!!,, )
I Have Had OK luck with carlisle tires. They Are OK but I like them for my little LT150 JD Lawn Tractor, but anything bigger than that i look at USA Made Tires.
/ DO NOT BUY SOLIDEAL TIRES. (TRIGGER WARNING) #62
I can not remember if the tires are USA, or not,,
I bought tubes, and installed them one afternoon, the tires, and trailer, are still in use,,
/ DO NOT BUY SOLIDEAL TIRES. (TRIGGER WARNING) #63
My experience with Solideal tires was a pair of 10.00 X 16.5 R4's for the front of my JD 4320. They were more than 1" narrower and about an inch shorter than the original Titans. Diameter is undersize enough to cause 4wd hard to engage and disengage.
/ DO NOT BUY SOLIDEAL TIRES. (TRIGGER WARNING) #64
A division of Camso is pods for atv's but I know them make them for AG tractors and many, many other machines. We used them on 2 machines for a few years. In the 6 years these were used, we far exceeded there original cost in repairs. Now I recommend and use Soucy built ones.. YRMV! 🤣
/ DO NOT BUY SOLIDEAL TIRES. (TRIGGER WARNING) #65
Keep in mind that a smaller diameter tire on the front can and will cause lead-lag issues with the driveline.
/ DO NOT BUY SOLIDEAL TIRES. (TRIGGER WARNING) #66
i have slowly replaced my stock bobcat tires with solideal just because les schwab(my local tire shop) stocks those. all the tires have worn about the same and gotten sliced up about the same, not cracking. Truly, they have lasted quite a few hours. IMO, if they still hold air and don
t wear out immediately i don't mind buying cheap tires. i have had many problems with cheap truck tires, mostly deformation and rarely buy the cheapest but never buy the upper end either.
I have the same exact size and i noticed that as well!
/ DO NOT BUY SOLIDEAL TIRES. (TRIGGER WARNING) #70
There is a local ag tire dealer that most people around here use. They sell mostly Titan and Goodyear.
I asked once about cheaper tires and they said they don't sell them.
rScotty
/ DO NOT BUY SOLIDEAL TIRES. (TRIGGER WARNING) #71
Carlisle’s crack all to hell in a year.
Yep, the ones that came on my Kubota when I brought it home brand new cracked immediately. All over the sidewalls.
So I called Carlisle and they were great. I sent pics and they sent me 4 brand new tires free of charge.
But then they did the same after a year. And my tractors are all kept inside except for when I am using them.
But then I recently bought another set through Kubota whole goods because you basically get the rims for free that way, and so far these ones have not cracked at all.
/ DO NOT BUY SOLIDEAL TIRES. (TRIGGER WARNING) #72
I have heard that some China tires cannot be patched. No bonding to whatever they are made of. Carlisle Tires like most everything else used to be good. Nothing stays the same.
/ DO NOT BUY SOLIDEAL TIRES. (TRIGGER WARNING) #73
If you want to buy cheap tires, just get BKT and be done with it. Hard to go wrong there.
John Deere W52R Walk Behing Mower (A64047)
John Deere W52R...
2013 ISUZU NQR 4X2 REFRIGERATED BOX (A59910)
2013 ISUZU NQR 4X2...
2020 FORD RANGER(INOPERABLE) (A63569)
2020 FORD...
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
CASE IH FARMALL 90C TRACTOR (A63290)
CASE IH FARMALL...
Oxy-acetylene Torch and Regulator Rig (A63118)
Oxy-acetylene...
