Busted rear diff dodge 2500
/ Busted rear diff dodge 2500 #61
…..is Cummins.
I guess I would have taken that set up too...Can't knock you for it.
However, with 150k and the current owner owning it from just recently...that is well past a factory defect. I don't know what would cause that failure. Maybe just dumb luck.
So you really didn't have to make any excuses for why it failed and I would have agreed with you. :LOL:
/ Busted rear diff dodge 2500 #62
The way the numbers are determined is by dividing the number of teeth on the ring gear by the number of teeth on the pinion, but that's probably not what you wanted to know.
Using 3.73 and 3.42 gearing as an example, the difference is about 10%, which means that the engine would turn 10% faster at a given speed with the 3.73s. And another 10% with 4.10s.
Lower gears (numerically high) are better for towing and put less strain on the drive train. They put more torque to the ground. Tall gears, like 3.42s, can deliver better mileage depending on the usage.
Think of it as levers. A short lever (3.42s) is harder to apply force with than a longer lever (3.73s), but you have to move your hand a slightly longer distance.
Hope that helps, Greg.
Too many kubotas, Thanks for the mental picture - that helps me get a grasp on the thought! I had a "kinda" idea but wasn't fully sure.
/ Busted rear diff dodge 2500 #63
/ Busted rear diff dodge 2500 #66
When semi trucks start running v8 diesels again let me know!
Scania has been doing it for a long time with their 16 litre V8 engine with 770 HP and over 2700 ft lbs of torque. :)
/ Busted rear diff dodge 2500 #68
When the biggest most powerful dozers (read CAT D10 and D11) start running inline 6's, let me know.
The V8 diesels in pu's these days last longer than the rest of the truck, that's good enough.
Those words from a guy that has Ford, Chevy and Dodge right now...
SR
/ Busted rear diff dodge 2500 #70
SR
V8’s are definitely in the minority when it comes to heavy equipment though… by far.
They started in the 1960s e.g., Cummins, Detroit and Mack to name three off the top of my head.
Yeah, but they’ve all been superseded now-a-days in the US by the inline 6 configuration.
Nothing like the sound of a 2 stroke Detroit Diesel though… 👍🏼
/ Busted rear diff dodge 2500 #75
The big Mack V-8 was pretty impressive, but loved fuel.
I like a red top N-14 myself.
L-9’s are nice in smaller trucks.
/ Busted rear diff dodge 2500 #77
The Mack V-8 was a boat anchor..
/ Busted rear diff dodge 2500 #78
/ Busted rear diff dodge 2500 #79
/ Busted rear diff dodge 2500 #80
Why’dja get rid of THAT?
I had learned about all I could about it, and Class 8 stuff in general, after having gone through it almost completely. Never did do anything with the wonderful Corvette dash, but replaced or rebuilt just about everything else.
Replaced it and its custom toy hauler trailer (which started life as a basic dry van) with a normal toy hauler - which I don't use, either.
Too much to maintain here, vehicles and land, to go places. If I could stop building and modifying things it would be different, but apparently I can't stop.
2007 INTERNATIONAL 7400 SBA 4X2 VACUUM TRUCK (A63276)
2007 INTERNATIONAL...
2019 CAT 259D (A60462)
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A63276)
2017 FORD F-350 XL...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
2010 John Deere 4720 (A64126)
2010 John Deere...
2007 Load - Max Loadmaster Gooseneck Trailer (A66285)
2007 Load - Max...
