Field work
/ Field work #1
repete
SW Washington
L2550DT IH584-4WD
Wife caught me working on 5 of the 40 acres today with the faithful little L2550DT. Turned 6,330 hours today.
/ Field work #4
Like the old saying goes..."If you take care of it,it will take care of you" and by the looks you have. (y)
/ Field work
Oil change every 100 hours and regular grease. Two clutches I believe, a lot of $ in the front axle from asking it to lift too much and reinforcing of loader arms. Fortunately, beyond the valve covers being off for valve adjustment I have never had the engine apart including fuel injectors etc.
It is a tough little guy and will serve well with some care.
/ Field work #7
Yeah, I don't do that either. That would be a lot of oil changing for me.
/ Field work #8
100h sound like a lot but I change mine once a year at the end of the summer ( I don't use it during the winter or very little) regardless of the hours I change it at that time, it's mostly would be anywhere between 100h to 200h. My owner manual ask for every 200h I believe.
/ Field work
I look at the posts about electronics and air pollution stuff and a host of other items that may cause a new tractor to go to the shop for repair so for about the same cost as 15 minutes of shop time I can do an oil change to keep this purely mechanical tractor running.
/ Field work #10
Oil costs too much to throw it away unused IMHO 100 hour oil changes are not needed but won't hurt anything but your wallet. lol
Neighbor has had a 30 hp Kubota for about 20 yrs now. .. I 've told this before but last year I asked if he was doing his own oil changes. He said no, I've never changed the oil. :oops: o_O
One extreme and the other yet both tractors are running.
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
36"x12' Stacks of Sheet Metal (A60463)
36"x12' Stacks of...
2019 KUBOTA SVL95-2S SKID STEER (A62129)
2019 KUBOTA...
2019 Ford F-150 Crew Cab Pickup Truck (A59230)
2019 Ford F-150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
