Oil & Fuel Coolant
/ Coolant #1
Wvanatti
John Deere 2305 (2010)
I have a 2010 JD2305. I changed the coolant yesterday. I went to the auto parts store and purchased comparable antifreeze. Once home, I panicked- just didn’t want to take a chance with my beloved baby. So I read the book and ordered the recommended TY26576 fluid. Once I received the box, I drained the radiator, eng block and reservoir per the manual. (Easy). Stated adding the fluid. Noticed the color was lighter, not green. When I was all done... seen the jug Deer sent me was TY26575. Not 76. Does anyone know the difference? I can’t find any on it. Thoughts ?
/ Coolant #2
That is correct. For some reason the JD Cool-Gard II is a light yellow instead of bright green. I wish they would have stayed with bright green as it is easier to identify when it leaks. As for the part numbers. The difference is the size of the container.
TY26575 is 1 gallon jug of pre-mix
TY26576 is 2.5 gallon jug of pre-mix
/ Coolant
Wow, Thank you so much for that info. I was afraid it didn’t have the correct rust inhibitors or blah blah...
Really appreciate that peace of mind you just gave me. Bill
/ Coolant #4
How much command did it take? Manual says 3.4 quarts but I added the whole gallon of cool-gard II and it seems to need more. Thanks for any info
/ Coolant #5
Just a side note since we're talking about coolant. There is a green coolant and an orange coolant. They are not compatible with each other. If you mix them, they form sludge in your cooling system. It's been awhile since I researched this so I don't remember the specific technology behind them anymore. Just don't mix them.
/ Coolant #6
Welcome to TBN
You prolly meant coolant?
/ Coolant #7
And it makes a royal mess inside the engine.
2016 Ford F-550 Auto Crane 4004EH Service Truck (A64556)
2016 Ford F-550...
2024 Texoma 16ft. T/A Equipment Trailer (A68183)
2024 Texoma 16ft...
2018 GENERAC MOBILE PRODUCTS MTL6S (A67714)
2018 GENERAC...
2001 Ferguson 46A Double Drum Roller (A67714)
2001 Ferguson 46A...
PORTA POTTY (A67714)
2014 HIPOWER 310 Generator (A67714)
2014 HIPOWER 310...
