Flail mower help
/ Flail mower help #1
rhuffie
Member
Mariposa, Ca
Kubota 3902 Had to give up my beloved 1952 Cat 12 motor grader
I have been looking for a 60" flail mower for my 30 HP PTO Kubota L3902. There are many of these machines visible on the internet but few of those brands are handled by dealers in my area. Online there is one that is very inexpensive but also appears in many ads and Youtube videos under the banner of many different brands ..and yet all are under the smae designation "EFCG 1555"?! It is made in China. So my choice seems to be a Gearmore, JD or Virismo. I am trending towards the Virismo becaused it seems to be engineered for tractors with 30HP and so are a bit lighter then many of the others. Also, it is not only made in the USA but thier business is located near me in central Cali. Reviews of any of these particular machines is scarce to non existent. Any thoughts from folks with experience with these machines?
/ Flail mower help #2
Virismo is a good brand.
I bought a Woodmaxx only because they are within driving distance if I needed parts down the line. So far, so good!
/ Flail mower help #3
Hello and good evening rhuffie,
The VRISIMO flail mowers have been made for a long time and the new owners
of the company have maintained the high quality building them.
There are plenty of videos of the Vrisimo mowers working in many mowing conditions
and in orchards as well.
You have to narrow down what you will be mowing and then decide which units suits you best.
When you go through and look at the flail mowers you may even want to have 4 caster wheels added
to the unit you wish to buy based solely on your mowing needs and how rough the ground is.
LeonZ
/ Flail mower help
LeonZ
The only videos i have found (three of them) are one minute long...in short grass, put out by the manufacturer. You have seen others?
/ Flail mower help #5
Wander over to youtube and type in Vrisimo and 6 or 7 of them pop up; then go to youtube and type in
vrisimo shredder to see more. Type in vrisimo shredder in google and you will see more of them.
/ Flail mower help #6
i was just looking at woodmax
/ Flail mower help #7
I just bought a Del Morino funny top, 158 M, 62 inches, rated for 12-30 HP tractors, made in Italy. I asked my Kioti dealer if he had a distributer that handled them, and he found one in stock locally and confirmed that he would be able to get parts relatively quickly.
/ Flail mower help
I just spoke to the folks at Vrismo as to whetether they use a slip clutch of shear pin on their machines in order to protect the transmission from damage should the mower run over some barbed wire or...? I was told that they employ neither of these devices because in the event of such a problem, the belts would slip and then start smoking, protecting the trans from damage. Does this sound resonable?
/ Flail mower help
I just spoke to the folks at Vrismo as to whether they use a slip clutch of shear pin on their machines in order to protect the transmission from damage should the mower run over some barbed wire or...? I was told that they employ neither of these devices because in the event of such a problem, the belts would slip and then start smoking, protecting the trans from damage. Does this sound reasonable?
/ Flail mower help
I just spoke to the folks at Vrismo as to whether they use a slip clutch of shear pin in their machines in order to protect the transmission from damage should the mower run over some barbed wire or...? I was told that they employ neither of these devices because in the event of such a problem, the belts would slip and then start smoking, protecting the trans from damage. Does this sound reasonable?
/ Flail mower help #11
Years ago I bought a couple of used 6` flail cutters for a couple of hundred each. Ordered new knives and misc parts online, along with a minimal amount of paint and have a couple of decent cutters for under $600 each. I've had them so long now that they are both ready to be freshened up again. One is a John Deere and the other is a Befco.
/ Flail mower help #12
My Maschio doesn't have a slip clutch or any shear pins. Flail mowers absolutely depend on the belts to slip to prevent a catastrophic failure.
/ Flail mower help #13
Yes, this is how the flail mower/flail crop shredder/ boom mounted orchard and vineyard shredder are protected.
The V belt drive system is an indirect drive which is the best defense for a flail mower.
/ Flail mower help
Thanks for your help!
/ Flail mower help #15
I'm not sure if all flails have this feature but for tractors with a PTO brake the "freewheel" feature is almost mandatory. If you don't have it you definitely need an over run clutch.
/ Flail mower help #16
I have a Bestco flail mower # FH-EFGC195 77" for 35 hp tractors. They have smaller models available. This has been a cost effective buy under $3k delivered. There is a flail mower learning curve. I smoked a set of belts (it uses 3 belts $85). And I trashed a set of cutting hammers mowing rocks. I can reclaim the hammers later but it was a paying job so I just put the money into a second set. 32 pieces I believe.
With flail mowers you have a choice of knives or hammer style cutters. Hammers reduce brush to kindling and knives give a better finished cut on weeds and grasses but fail on the big stuff. A well kept set of hammers can give a decent field cut and still take down saplings and mulch downed branches.
/ Flail mower help
LeonZ
My ground is quite rough. When I was looking at some of the larger ag mowers i see many do indeed have casters attached to the backside of the mower case. Perhaps welding brackets with holes to allow attaching and removing the casters with a nut and bolt would be a good idea for dealing with the uneven nature of my land by allowing the mower to float over the landscape held up with only the front rollers and casters. Is this what you were referring to in your post?
/ Flail mower help
Yes that is the chinese made tractor that is offered for sale under many brand names on many different internet websites.
Farmer's Helper is an example of this "EFCG1..." Mower.
Some dealers also carry these.
/ Flail mower help #19
In order for caster wheels to be effective the mount to the machine needs to be a hinge or float
/ Flail mower help #20
Please listen.
The large flail crop shredders do not make use of a rear roller as they are supported by the very thick flail mower shroud and the rear tubular weldment that prevents the flail mower shroud from twisting and wracking by also using the rear tubular weldment that prevents the mower from being damaged.
The very large flail crop shredders are used in ridge tillage to shred the crop waste on the ridges and the wheels ride in the bottom of the row between the ridges.
If you order a small VRISIMO flail mower with caster wheels you will be sold a machine with either 2 or 4 casters which make the attachment a stable mowing platform.
The rear roller of the flail mower regulates the mower height as long as the top link is set correctly making the mower level as long as you lock the hydraulic lift at the desired
height.
You need to decide how much money you with to spend and what cutting width you want before you decide on a flail mower brand and whether it has side slicer, scoop/spoon knives or cast hammer knives and go from there as the cast hammer and scoop knives will not recut the brush on the second pass as they do not have adequate lift/pressure gradient to create the suction need to lift and recut the clippings/brush.
2005 Little Wonder High Output Walk-Behind Blower (A64553)
2005 Little Wonder...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
SHOPBUILT MESH BOTTOM TRAILER (A64278)
SHOPBUILT MESH...
JMR 72in Dual Cylinder Grapple Rake Skid Steer Attachment (A64553)
JMR 72in Dual...
Man Basket Boom Lift Attachment (A64553)
Man Basket Boom...
