Dump Trailer Concern
   / Dump Trailer Concern #1
LittleBill21
Elite Member
PA
Mahindra Max 26XL, White
I am considering buying this, this week, has anyone used one of these? the rear panel has me concerned since if you put enough weight against it, I assume I will struggle to remove the gate/ ramp?
I wish it had doors, but it seems like only larger models do, and this is about the weight limit I can handle right now,
any suggestions?
   / Dump Trailer Concern #2
I have no knowledge on that dump trailer but a Friend has one of the sure-trac utility trailers and he has commented it is a light duty trailer compared to PJ and Load Trail sold at same dealer ship.
The load trail version of this trailer is 200 pounds less and 500 pounds less payload...
   / Dump Trailer Concern #4
those ramps look like they would be slicker than owl ---- when wet be careful
   / Dump Trailer Concern #5
Carry a shovel & clear the panel for removal. If you're really worried about it, you could probably fab up some doors & weld them on, but you'd lose a "ramp" if that matters. The Ramps look too slick & light duty for me, but might be ok for a garden tractor in dry conditions.
   / Dump Trailer Concern #6
I recommend you move up to the 5'x8' way more features.
   / Dump Trailer Concern #7
If your just using it in your yard I would leave the rear (gate, ramp) off.
they have some kind of coating, but I don't plan to use them I have a utility trailer for loading
   / Dump Trailer Concern #10
What happens when you get a dead battery? How do you get to it to recharge it?
Toro Sand Pro (A56859)
SKID STEER ATTACHMENT AUGER (A58214)
SKID STEER...
TANK MANIFOLD (A55745)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
