4WD and loader work
/ 4WD and loader work #42
I like Hay dude's response. Put it in 4wd when it needs to be and take it out when it doesn't. That is different for every single person on this thread.
I don't know what percentage mine is in 4wd, depends on the day and the job.
/ 4WD and loader work #43
After 6,300 hours on my L2500DT I have learned to use 4WD when I need it. Get it out if I do not.
I have pulled the front differential to replace the little 3/4" or so splined coupling that connect the two halves of the front driveline. Not a repair I liked.
I have replaced the front tires many times mostly due to friction wear obviously. When I have a load in the bucket and the front tires are compressed and it is in 4WD, I have changed the front and rear rotation ration due to the diminished radius of the front tire, something must give. The only option is for one axle's tires to slip on the surface -or- break something as there is no clutch in the system to slip. (I do like the IH584 due to the clutch engagement of the 4WD but even so, I put it in and get it out ASAP)
I know this flies in the face of those who leave their tractors in 4WD all the time but I get it out immediately when there is no longer a need for 4WD. When others get to the 6300 hour mark on their 29 HP tractors I will be all ears to listen to how they use and care for their machines.
/ 4WD and loader work #44
I suggest you get rid of that Kubota if you are doing any further loader work. The LX2610 is a “wannabe“ loader. Step it up to a Caterpillar 994 and quit wasting you time and worries with the 🍊 crate.
/ 4WD and loader work #45
Gonna need a little bigger tractor shed.
/ 4WD and loader work #46
/ 4WD and loader work #47
These two hardly ever get put in 4x4. Only in a very wet condition going straight. Then directly back into 2wd. And yes, they are worked a lot. Never any trouble.
/ 4WD and loader work #48
The real time y;ou don't want to be in 4X4 is on pavement. I only use use 4X4 when I need it.
willy
/ 4WD and loader work #49
As long as you aren't on dry asphalt and tight turning constantly you'll be ok.
/ 4WD and loader work #50
This is my first 4wd tractor. Thus far in a soft and fluffy field, tilling and general loader work, I’ve not needed 4wd. I use it, if I need it… which is/will be rare. It’s nice to have, but growing up, none of the old IH tractors on the farm had 4wd assist. The 4820 Branson is over 5000# already, with a large patch of tire on the ground. I can see the need for 4wd in the winter if I move some snow.
/ 4WD and loader work #51
I only use it when I need it, also I try not to do tight turns when I'm in 4wd.
/ 4WD and loader work #52
In all my life, everything from my little Kubota to a full size backhoe has never been OUT of 4WD and I have never wore front tires or broke anything.
Now mind you I'm not running 4WD on dry asphalt.
  • Good Post
Reactions: JWR
/ 4WD and loader work #53
your going to learn people have no idea what they are talking about, gear grinding is clear as can be, do you hear it? prolly not, its generally a open differential, there is a reason they have lockers. if your not hearing noise, your not doing damage. i use 4x4 constantly and was slipping non stop today dealing with a flood.
do you know how much my wheels slip while plowing?
I am with this guy. I use 4x4 almost all the time for 12 years. No problems yet. The reason they put 4WD on compact tractors is they are so light weight you can't do anything in 2WD.
/ 4WD and loader work #54
I read in the manual for my LX2610 that it's fine to work in 4WD doing loader work, which I have been doing. I watched a video with Tractor Time with Tim and one of the comments was that he should not being doing loader work in 4WD as it's gear on gear drive and its grinding gears when one of the front wheels spins and the other doesn't.
I just want to make sure that I'm not doing anything wrong.
Edit:
I should have been more clear, TTWT was doing similar work as I was, a commenter, not Tim, said that.
If you hear gears grinding you have Expensive Damage already. Take it to the Dealer and get it repaired. Never use 4WD unless you Need to. Just wear and tear on pricey parts.
/ 4WD and loader work #55
I keep the 1999 Kubota L3710 in 2wd unless I'm losing traction with the rear tires. After using it for 20 years on the same property for the same tasks it instinctive now. For example, scooping up a bucket of 3/4 crush and heading down the steep driveway, better have it in FWA if you don't want to slide down the hill with the rears locked up. Plowing snow, better have it in FWA. Tilling the garden, FWA or it won't turn in the deep lose soil. The easiest way to shift it in and out of FWA is to lift the front wheel off the ground with the bucket. My rears are loaded btw.
/ 4WD and loader work #56
Edit:
Use four wheel drive when your rear wheels spin doing what ever you are doing. Only use two wheel drive when traveling at above normal working speeds or when using a tractor that has only two wheel drive. Workmaster 50 made in 2015. Bought new in 2016. It has been in four wheel drive 90 percent of the time since purchased. Put it in two wheel drive just ever so offen. With loader, if you spit on the ground it will spin rear wheels backing up a slight incline in two wheel drive.
/ 4WD and loader work #57
To be clear, it's safe to be in 4WD and be scooping dirt?
You can safely use 4wd anytime you are in conditions that will allow for slippage (not to mean tires must be slipping) as the front and rear tires turn at different rates of speed (normal operation when front and rear tires are different sizes). You should not use 4wd when on solid surfaces—concrete, asphalt or extremely hard packed soils.
/ 4WD and loader work #58
I live on 80 acres. I use 4WD when I need it. OTHERWISE - I'm always in 2WD. I've never needed 4WD when doing grapple or bucket work. Winter snow plowing or muddy areas - sometimes yes. Replacing driveline components or gears is a very expensive venture. I've never had problems with my tractors - doing it the way I do.
My thought - do not force the tires to slip just because you are in 4WD. Use 4WD to provide added traction and get you out of a "sticky situation". Field observation/anticipation/common sense will help your drive line system last a whole lot longer.
/ 4WD and loader work #59
4wd should always be engaged for loader work, but don‘t engage it on pavement unless your moving snow. Never use the foot pedal that locks the rear, until you’re stuck. It’s your last resort to get out of a bad situation.
/ 4WD and loader work #60
The dealer had told me that they use 4WD for all loader work. I moved a mount of soil over the weekend on un even ground which is why one of the wheels had spun, plus it was pretty wet. I'm confused as to why the manual shows what it does below for 4WD.
This page says using 4wd is "effective" when doing loader work, and while in pavement (increased tire wear). The point made about damage is by forcing the 4x4 lever into position rather than a smooth action by lining up the gears by stepping forward or backwards on the pedal.
I generally use 4x4 when loading on soil and avoid 4x4 on pavement, unless it's wet and slippery, to save my tires. When loading, I get a very full bucket in 4x4, i find I get a smaller load in the bucket and the rear wheels tend to slip when not in 4x4 and I have a backhoe but not loaded tires.
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
(2) TRAILER RAMPS (A62131)
(2) TRAILER RAMPS...
John Deere 6110M (A60462)
John Deere 6110M...
CASE IH 8950 TRACTOR (A62130)
CASE IH 8950...
John Deere Decorative Metal Sign (A61569)
John Deere...
2020 International LT625 Sleeper 48" (A62613)
2020 International...
