Help Identifying A Couple 3-Point Implements!
/ Help Identifying A Couple 3-Point Implements! #1
wirlybird
Gold Member
Oklahoma
John Deere 3038 E, John Deere 3032E, John Deere 756, John Deere X585, John Deere 332
Hi all,
A friend has these and is going to sell so I'd like to try to identify the brand, etc. and maybe a value.
One is what looks like a 3 foot box blade. Quite heavy duty and in good shape.
The other is a small disc, maybe a few feet wide, and also seems in decent shape.
Thanks.
/ Help Identifying A Couple 3-Point Implements! #3
Looks like tuffline, or Monroe Tuffline. Disc is an offset disc. Tuffline box blades had that type of hitch. Their stuff was yellow also. But, just a guess.
/ Help Identifying A Couple 3-Point Implements! #5
In surprised that little box blade is cat1, but it looks like it is. Cat0 would have all 3 holes be 5/8”. That one looks more like the 7/8” bottom, 3/4” top which is cat1. I have never seen a cat1 box blade so narrow. It does look built well!
It is Cat 1 and it is also very heavy.
It was suggested it was cut down from a larger one but it really doesn't look like it.
Very odd one.
/ Help Identifying A Couple 3-Point Implements! #7
The narrow Disc Harrow looks like it was cut down too.
Note: 1) box frame 2) notched front but smooth rear pans. (discs)
3) The pipe may be the attachment point for a drag chain harrow.
What a lot of work!
/ Help Identifying A Couple 3-Point Implements! #8
What a lot of work!
When i saw the pipe my first thought was “ho cool the previous owner must i’ve place a bunch of gym weights on there “ i think that’s a better explanation then a tie off point.
/ Help Identifying A Couple 3-Point Implements! #9
What a lot of work!
why do you say the disk harrow was cut down ? i don’t see any evidence that would indicate that ?
/ Help Identifying A Couple 3-Point Implements! #10
Entirely possible, even likely. However, supplemental weight would be more effective located over the front row of pans which are notched for cutting/penetration, rather than the rear row of pans, which are smooth, therefore tend to roll rather than displace soil.
/ Help Identifying A Couple 3-Point Implements! #11
good point, I am assuming the previous owner reasoning was further away the weigh is from the hinge heavier it is although in this case it is not applicable since the 3 point only act as a hinge once the disk is off the ground, or it is simply where there was room. The way he welded it in place cancel the adjust the rear disk which is not also not ideal ...
213141 (A64276)
213141 (A64276)
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
2019 JOHN DEERE 331G SKID STEER (A65053)
2019 JOHN DEERE...
New 2x27 Ratchet Strap (A65583)
New 2x27 Ratchet...
2006 FREIGHTLINER COLUMBIA (INOPERABLE) (A65643)
2006 FREIGHTLINER...
2005 Polaris Sportsman 700 EFI (A66408)
2005 Polaris...
