Help Identifying A Couple 3-Point Implements!
   / Help Identifying A Couple 3-Point Implements! #1
wirlybird
Oklahoma
John Deere 3038 E, John Deere 3032E, John Deere 756, John Deere X585, John Deere 332
Hi all,
A friend has these and is going to sell so I'd like to try to identify the brand, etc. and maybe a value.
One is what looks like a 3 foot box blade. Quite heavy duty and in good shape.
The other is a small disc, maybe a few feet wide, and also seems in decent shape.
Thanks.
   / Help Identifying A Couple 3-Point Implements! #3
Looks like tuffline, or Monroe Tuffline. Disc is an offset disc. Tuffline box blades had that type of hitch. Their stuff was yellow also. But, just a guess.
   / Help Identifying A Couple 3-Point Implements! #5
In surprised that little box blade is cat1, but it looks like it is. Cat0 would have all 3 holes be 5/8”. That one looks more like the 7/8” bottom, 3/4” top which is cat1. I have never seen a cat1 box blade so narrow. It does look built well!
It is Cat 1 and it is also very heavy.
It was suggested it was cut down from a larger one but it really doesn't look like it.
Very odd one.
   / Help Identifying A Couple 3-Point Implements! #7
The narrow Disc Harrow looks like it was cut down too.
Note: 1) box frame 2) notched front but smooth rear pans. (discs)
3) The pipe may be the attachment point for a drag chain harrow.
What a lot of work!
   / Help Identifying A Couple 3-Point Implements! #8
What a lot of work!
When i saw the pipe my first thought was “ho cool the previous owner must i’ve place a bunch of gym weights on there “ i think that’s a better explanation then a tie off point.
   / Help Identifying A Couple 3-Point Implements! #9
What a lot of work!
why do you say the disk harrow was cut down ? i don’t see any evidence that would indicate that ?
   / Help Identifying A Couple 3-Point Implements! #10
Entirely possible, even likely. However, supplemental weight would be more effective located over the front row of pans which are notched for cutting/penetration, rather than the rear row of pans, which are smooth, therefore tend to roll rather than displace soil.
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A55315)
Adams Load Out...
2010 Ford Fusion Sedan (A53424)
2010 Ford Fusion...
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
2024 CRATOS ES-800 ELECTRIC DUMPER (A57192)
2024 CRATOS ES-800...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2012 International...
