Oil level in a gear box
/ Oil level in a gear box #1
marhar
Gold Member
Denton NC
Farm Trac 60
I just bought a Country Line post-hole auger. The manual specifies the oil weight and says to fill to the correct level. The level is not specified. What is the correct level?
I have a rotary cutter that specifies not to fill the gearbox more than 1/2 full. Are post-hole augers the same?
/ Oil level in a gear box #2
If there's not a oil level check bolt I would go with an estimate of 1/2 full.
/ Oil level in a gear box #3
Agree with no more than half full. If you put too much it will push it out. A third to half should be fine. I deal with lots of gear boxes. I checked 50 boxes a month ago. Make sure your vent is clear.
/ Oil level in a gear box #4
Usually there is a pipe plug or bolt that is about half way up on the side of the gear box to remove for checking the oil level. I borrowed my neighbors Country Line digger back in November to set a couple of posts and it had a plug on the side so I assume yours will too.
/ Oil level in a gear box #5
I fill the gear housings on my snow blower and flail mower to the bottom of the fill plug opening
It does have a pipe plug just over halfway up. When I posted the question, I also contacted the mfg; you are correct! Thank you.
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 Brush Cutter (A64553)
2016 New Holland...
Steel Wheelbarrow (A65640)
Steel Wheelbarrow...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
Case 90XT Skidsteer Loader (A66285)
Case 90XT...
2011 Jeep Grand Cherokee Laredo SUV (A64557)
2011 Jeep Grand...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
