Oil level in a gear box
   / Oil level in a gear box #1
marhar
Denton NC
Farm Trac 60
I just bought a Country Line post-hole auger. The manual specifies the oil weight and says to fill to the correct level. The level is not specified. What is the correct level?
I have a rotary cutter that specifies not to fill the gearbox more than 1/2 full. Are post-hole augers the same?
   / Oil level in a gear box #2
If there's not a oil level check bolt I would go with an estimate of 1/2 full.
   / Oil level in a gear box #3
Agree with no more than half full. If you put too much it will push it out. A third to half should be fine. I deal with lots of gear boxes. I checked 50 boxes a month ago. Make sure your vent is clear.
   / Oil level in a gear box #4
Usually there is a pipe plug or bolt that is about half way up on the side of the gear box to remove for checking the oil level. I borrowed my neighbors Country Line digger back in November to set a couple of posts and it had a plug on the side so I assume yours will too.
   / Oil level in a gear box #5
I fill the gear housings on my snow blower and flail mower to the bottom of the fill plug opening
It does have a pipe plug just over halfway up. When I posted the question, I also contacted the mfg; you are correct! Thank you.
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2006 International 9400i (A55302)
2006 International...
New/Unused Electric 3-Wheeler (A57453)
New/Unused...
Sakai SV540T Padfoot Compact Roller (A57453)
Sakai SV540T...
2010 Ford Fusion Sedan (A56859)
2010 Ford Fusion...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
