IH674 front tires with studs
/ IH674 front tires with studs #1
domains
In winter on ice it slides alot, thinking of placing 16inch truck tires with studs, Will it help? I can bring blower closer to tractor with a bolt slot but would have to cut shaft shorter and the angle pinch would get worst, not sure what to do, cut shaft or get studded tires or both?
/ IH674 front tires with studs #2
Studs will help.
There are screw in studs available for this purpose. It's definitely the more the better.
There's lots of threads here on the topic but I've never mastered the search feature.
/ IH674 front tires with studs #3
Studded tires will help a small amount, studded chains will help more.
Those tractors were light on the front ends so they do tend to lack turning bite.
/ IH674 front tires with studs #4
You'll still slide with studs.
Leave brakes unlocked and use left & right as needed.
I used 2wd for years for snow removal, steering brakes necessary even with a loader on the front.
2wd with no loader & blower on the back you only want the front to stay planted enough for steering on the clear road, otherwise you want the weight on the drive tires.
Thats what i do i steer with breaks, but don't want to ware them down, some say they last a long time
I placed new tires otherday on back and I asked guy 20 years in service if I used threaded studs if it would help and he said they rip out in time
But factory studs would not rip out, I asked If I placed calcium in front tires and he said would not help much, I need to weld myself a box up front and fill with cement i guess
cause tractor weights are pricey like 1000$
if i bring blower 4inches closer I don't think it would help much, dealer told me to do that
/ IH674 front tires with studs #7
I wouldn't bother doing that unless the blower was so heavy that I was having trouble lifting it.
The service breaks are wet brakes and will last well, the parking brake will go fast if you drive with it engaged.
They are not cheap to replace but not the worst.
My friend has a 574 and forgot parking break on now one side only breaks alittle, Id have to look but I don't think I have one , i'm sure i never used it and brakes fine both wheels, must be a big job to replace with a cab, I might change hydraulic fluid filter this summer, it might be original , oil looks new on dip stick , friend changed his and said only a little fluid comes out and no need to bleed system
Do you have to bleed system when you change filter? maybe thats his issue
/ IH674 front tires with studs #10
I have studded tires on the rear of my tractor with r4's and they do well on ice but my driveway is flat. I can still slide around but it does give a bit more traction and they seem to be staying on well. I only have a few that have pulled out.
any hills though and you really need chains if you are dealing with ice. I'm not sure how helpful the studs on the front tires will be if there is no weight to put on them.
Ya I need studded tires and weight , its not bad i only need to play with the brakes in maybe 3 storms a winter, we get about 12-15
/ IH674 front tires with studs #12
Here's an old pic of my 574 pushing snow with a back blade;
My neighbour thats one of my best friends had chains that would fit on my tractor with a little modding and a back blade, He sold the chains 100$ and 200$ for back blade, He had no clue id want them
/ IH674 front tires with studs #15
Chains make a huge difference. Just keep them tight or you will be damaging fenders etc.
Can't drive on pave with chains and i open my moms driveway 1/4 mile away id do it anyway if i found cheap chains , I can lock my back diff and both our houses are flat driveways i'm ok, plus calcium in tires
/ IH674 front tires with studs #17
I'd hate to total up all the miles we have put on chains on pavement, 3 miles from my place to the farm. The feed lot tractors get 5-6 miles every day with chains on when the fields are or roads are bad. Easily 150-200 miles per year on pavement.
/ IH674 front tires with studs #18
You can, just not very fast, I drove longer distances on pavement for years with chains. Preference is without with the distance though.
I meant by law you can't, Thats what people tell me
2023 Unused HLA 2.5 Yard Loader Bucket Attachment (A66734)
2023 Unused HLA...
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2019 FOREST RIVER WILDWOOD (A67714)
2019 FOREST RIVER...
2013 Chevrolet Cruze Sedan (A66738)
2013 Chevrolet...
CAT 988B Final Drive (A68134)
CAT 988B Final...
