3038e buying advice
/ 3038e buying advice #1
coloradotrout
Gold Member
Eastern KS
JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
Anything to look at in particular about this tractor and FEL with 300 hours?
I have a hst 4100 with FEL. I'd like more HP to run the tiller, etc.
What price should I expect?
Any major issues to look out for?
/ 3038e buying advice #2
If you purchase the Deere 30038e you will have 50% more weight and twice the power relative to your current Deere 4100.
A worthwhile upgrade.
Excellent. Thank you. I'd like the R lift capacity but not enough to pay for it I think.
While test driving this appeared
ICC 003695.03 (ICC 3695.03)- Diesel Particulate Filter Regeneration Inhibit Switch Voltage above normal, or shorted to high source
Regen inhibit switch stuck on or short to power
It was intermittent. Nothing at startup. Engine was cold. Then after 15 minutes it came on. Then it went off at shutdown, but came on again later.
Did some searching. What about LS 35 to 40 hp models?
/ 3038e buying advice #6
I researched tractors for 2 years, and the only reason I decided against an LS, was the ECM engine and numerous safety switches/ecm/DPF that caused the tractor not to run, or to go into limp. I bought a TYM with a mechanical engine, no limp mode, no seat switches, no ECM control of the engine. It is probably the only manufacturer still using mechanical injection
/ 3038e buying advice #7
Some of the early 3038E's had a hydraulic seal go bad around the PTO shaft area. Pretty common problem per my dealer. About $300 for the dealer to fix it.
/ 3038e buying advice #8
That won't last either....lol
/ 3038e buying advice #9
I considered the 3038e and a couple Kubota's years ago but when it came time to decide, I went with LS, got more tractor for much less money.
It's a 2020 and I have put on 252 hours and no issues so far. It flashed an error code early on but I shut it off , restarted and it has never come back. I did tighten up the ground lugs as I have often seen recommended for various codes.
I got it with the backhoe (Only $4500 then, been well worth it) and I've used an EA grapple, TerraForce tiller, disk, pallet forks, and a Bush hog BH215 brush hog.
/ 3038e buying advice #11
candidly, the one brand I steer clear of is JD and we have a stocking dealer nearby. My issue with JD in general is they are extremely 'proud' of their offerings and price them accordingly and they really don't like to negotiate on price either.
So long as there is a stocking (parts available) dealer nearby, brand makes little difference because at some point you will need a dealer.
Which is easier to work on instead of paying the dealer 150/h?
/ 3038e buying advice #13
In Theory the TYM since it has minimal electronics, otherwise then they are probably similar.
There wasn't a TYM dealer near me when I was researching only a Branson dealer (now a TYM dealer) and the reviews at the time weren't great and the price was a little more than the LS.
So if I was shopping today I would look at TYM closer as well as LS and probably New Holland, MF and Case IH.
/ 3038e buying advice #14
Many Case IH compacts, are made by TYM. Formerly by the Kukje division, now just rolled into TYM.
/ 3038e buying advice #18
13 years on our 2010 3038e. Predates the DPF thing. No issues that weren't self inflicted other than minor dash issues (PTO light goes off sometimes & sometimes the tach needs a couple of taps to come off zero)
/ 3038e buying advice #19
I think they are made by LS actually. I've seen many articles showing such.
In January this year, CNH Industrial renewed a contract with LS for Case IH and New Holland branded compact and utility tractors first signed in 2010
/ 3038e buying advice #20
2021 KUBOTA SVL75-2 SKID STEER (A64279)
2021 KUBOTA...
(1) 235/80R16 TIRE W/ (8) LUG WHEEL (A64280)
(1) 235/80R16 TIRE...
2017 Ford F-250 Pickup Truck (A61573)
2017 Ford F-250...
2023 Kubota L6060HST Compact Utility Tractor (A63688)
2023 Kubota...
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2021 Chevrolet...
2019 CAT 305E2 CR Mini Excavator (A62613)
2019 CAT 305E2 CR...
