3320 Stops running
/ 3320 Stops running #1
barrest
Sealy, Texas
MF 135
Zetor 3320. 1991 year
Runs for about 20 mins then just quits. Release the bleed nipple and crank and she starts, runs 10-15 mins and quits again. I’ve replace the pump, both fuel filters and all rubber fuel lines. I’m not a diesel mechanic.
Any ideas??
/ 3320 Stops running #2
G'day Mate. Have you put an inspection camera down into the fuel tank to look for any 'crud' (biological growth or debris) that would be blocking or restricting fuel getting to the system?
I ran a hose from the filler neck of the tank direct to the filter inlet bypassing the tank feed pipes. Same result, 20 mins of running then quits, bleed the system and it runs for 15-20 mins then quits again.
/ 3320 Stops running #4
Hmmm... well 'something' is blocking, what I suspect, is fuel continuing to reach the injectors. I mean, the whole system 'works' for 15-20 minutes and there's only 3 things that you need for ignition = fuel, air, and spark. If it 'works' for 15-20 minutes there must be sufficient air & spark (compression) for it to operate... that leaves fuel, which sounds like there's enough fuel after 'pausing' for some sort of 'reservoir' of fuel to gather which isn't being regenerated.
Sorry, but someone else is going to have to join the thread to offer an alternative solution.
/ 3320 Stops running #6
Is the pump you replaced a lift pump? Is it electric or mechanical?
It’s mechanical and bolts to the injector pump. Would an electric pump delivering fuel to the injector pump directly, bypassing all the filters work and if so what psi and volume would it need to be? The return line for unused fuel would remain connected. I need to have the filters I know but I need it to run for more than a few minutes to eliminate the injector pump.
/ 3320 Stops running #8
I’ll give it a try. I have a spare pump in the barn
Should there be foam/small bubbles in the glass bowl on the primary filter?
/ 3320 Stops running #12
No. There is a leak somewhere causing your issues.
/ 3320 Stops running #13
Any updates?
The problem seems to have been 2 fold. One of the copper washers on the fuel delivery union was damaged (probably from the several times it was dismantled for new pump, new primer and new glass filter bowl allowing air into the bowl, hence the small bubbles) but the original cause I believe to be sediment in the fuel tank slowly blocking delivery. I had flushed out the tank but obviously not well enough. All running now. Thanks for all the people who offered help and assistance.
Michael
/ 3320 Stops running #15
Glad you got it going. Thanks for the update.
211298 (A62131)
211298 (A62131)
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
Farmall Super A Tractor (A62613)
Farmall Super A...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
