Need to protect a small inverter & battery on an outdoor post
/ Need to protect a small inverter & battery on an outdoor post #11
Look into a cheap plastic Sterilite from Walmart, drill some drain holes, modify as needed,
/edit - plan on replacing annually so maybe buy several
/ Need to protect a small inverter & battery on an outdoor post #12
Yeah, I don't know how Sterilite will hold up to UV and weather.
/ Need to protect a small inverter & battery on an outdoor post #13
Nema rated electrical enclosures including ventilated ones are frequently available surplus on ebay for good prices. I've purchased several that way.
/ Need to protect a small inverter & battery on an outdoor post #15
I was gonna say what MossRoad said: ventilated. This is very important. You really only need protection from rain so a big umbrella would work. But whatever you do make sure it is well ventilated. Otherwise moisture will condense on and inside your inverter. Add a lead acid battery and you are setting yourself up for pretty bad corrosion. I would also suggest you check out lithium motorcycle batteries. At least they don't outgas corrosive fumes like lead acid batteries. Good ventilation should make it possible to use lead acid batteries though.
Eric
Would it be a better idea to mount the inverter and battery in separate boxes?
/ Need to protect a small inverter & battery on an outdoor post #16
I mounted an electronic bird repeller in my orchard in a Sterilite box and got three seasons out of the box before it became brittle. I did store it out of the weather during off seasons.
/ Need to protect a small inverter & battery on an outdoor post #17
If the battery is completely sealed they could be in the same compartment.
Eric
/ Need to protect a small inverter & battery on an outdoor post #18
Tupperware. They make heavy duty "boxes" of all sizes and shapes. Get the correct size - turn it upside down - put it over your inverter and battery - attach to post. Leave the bottom open for ventilation.
/ Need to protect a small inverter & battery on an outdoor post #19
But then you have to host a party and get your friends to buy some, too.
/ Need to protect a small inverter & battery on an outdoor post #20
Build small box wooden. Use small pieces of sheet metal for roof. Leave one long side open for ventilaton / access
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2021 CATERPILLAR 302.7DCR EXCAVATOR (A62129)
2021 CATERPILLAR...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2020 DRAGON ESP...
2015 Cadillac ATS Sedan (A59231)
2015 Cadillac ATS...
2012 Toyota Camry Sedan (A59231)
2012 Toyota Camry...
