A lot of good information and that gave me plenty to think about. I appreciate everyone's input. After reading all the comments, I sat down and went though how I would likely use the tractor and how much HP I would actually need. As someone noted, guys with 30 hp tractors always wish they had a 50 hp, and 50 hp guys wish they had a 100 hp tractor. Another point someone mentioned, would a turbocharger be the best for my application? I would say no, I would prefer normally aspirated. I'm just not a fan of the added complexity of a turbocharger.
Weighing it all out, a 30+/- hp will likely be enough for what I need to do, mainly homeowner/hobby farm applications and some light material moving. Thinking back to my previous experience. I was quite satisfied with my
L3430. It did everything I asked from it 95% of the time. Except for a few rare times the front end loader couldn't lift the load for stuff such as bulk bags of mulch on a pallet, my 3 point forks typically lifted what the front end loader couldn't, after I filled up the front bucket to balance the load.
Clearly, some of you use your tractor much more than I would, and for far more demanding applications. As an example, I had my
L3430 for about 10 years, total use was 365 hours when it was sold. My use should be about the same. I'm not plowing fields or doing other heavy PTO work, likely using only a rotary cutter with the PTO will be about it. The one item I used the most on the tractor, was the FEL with a
grapple for moving trees and brush.
I returned to the dealer today. I looked at everything he has in stock in a cab. He had both MX5200 and MX6000, M4, M7 and larger, and he had one remaining
2022 Grand L 3560 Limited Edition. Ultimately, I settled on the Grand
L3560 Limited Edition, I added the front and rear remotes I wanted, mirrors, front and rear work lights, loaded/R4 tires, the LA-805 loader + bucket, and a Land Pride
grapple. The cost came in just under budget.
Thanks for everyone's input.
