Help! Micro hydro pipe expansion
/ Help! Micro hydro pipe expansion #1
Ktm rider
Member
Kubota MX5100
So I have doing a micro hydro project to power and heat my home. I laid 900 ft of 8” PVC pipe in extremely rocky soil just beside my creek. i haven’t buried it as of yet because I am installing the turbine side of the build and want to pressure test the pipe. My problem is the pipe is expanding and contracting and pulling our of a few random joints.
My question is this. Will the expansion/ contraction stop once I have water running continually through the pipe even though it’s still exposed? Or should I bury it before I do anything else? I would really like to be able to check for leaks before I cover it but I guess it if has a major leak when covered up I’ll know it regardless. Any suggestions?
/ Help! Micro hydro pipe expansion #2
First thoughts would be incorrect glue, improper joint prep, pipes not pushed in far enough and held in place while glue dries.... that kind of stuff. The joints shouldn't come apart ever once they're glued.
Also, what's the air temp in your location? Are they sitting in hot sun?
I started this project in the fall and it ran into 5he winter.so the temp varied wildly . I did find a chart online that shows the amount of expansion/ contraction to expect and this seems like a common problem.
Am I wrong in thinking once the water is ran through the pipe continually that the expansion/ contraction would settle down when the pipe temp stabilizes from the water temp?
/ Help! Micro hydro pipe expansion #6
Sunshine greatly affects expansion. Shading the pipe with a few inches of dirt may help as will filling it with running water (and shading it) - I have seen PVC pipe roll over when heated up in the sun.
/ Help! Micro hydro pipe expansion #7
I guess to late now, but 8" is a big pipe, and needs to be pretty thick to handle a lot of water pressure. What's your calculated static pressure at the bottom?
Around 24 psi.
/ Help! Micro hydro pipe expansion #9
Around 24 psi.
Oh not that much head then, so you do need the big pipe, cool project though, post some pics and specs. I have 40m of elevation at our place, but no water source at the top of the hill. I don't think pumped hydro micro storage really pencils out but I think it would be fun to mess around with when I have time.
/ Help! Micro hydro pipe expansion #10
In general, if you have a delta temp. change of 25 degrees F you will need to use expansion joints on your 900 foot run. (EDIT Covering with backfill may take care of this.)
If you back fill the trench (if there is a trench) so the pipe is covered and shaded you can reduce the temp variation imposed on it. The more backfill depth the less temperature change on the pipe.
On long runs it is best practice to install it all within a delta change of 20° F so the glued fittings are installed at the approximately the same temperature. I have worked on a few jobs that this was written into the specifications for installing PVC.
/ Help! Micro hydro pipe expansion #11
How to calculate thermal expansion or contraction in Sch. 40 PVC. See attached. This is for electrical PVC, but the same calculation is used for all PVC pipe.
  • PVC Expansion Joints.pdf
There is a trench. I looked into expansion joints. Unfortunately they are WAY out of my budget. I really wanted to put water to it before burying it to check for leaks But I guess I will know if it’s leaking either way.
I should have mentioned that I did install Fernco fitting in both places where it separated. theyre both in the first half of the run. However the latest separation came close to the bottom. So I. A bit concerned about the pressure on this Fernco. I may install one with the stainless reinforcement sleeve.
I posted some pics in a different thread a while back. Just search micro hydro
/ Help! Micro hydro pipe expansion #14
This thread is realative to my interests.
Is the water level above your feedpoint changing or constant?
i have another thread explaining my whole system. Just search MicroHydro Project
/ Help! Micro hydro pipe expansion #16
Mound the pipe backfill, leaving the joints exposed. PVC has a fairly large thermal expansion coefficient and doesn’t like changes in temperature.
For example, the coefficient of thermal expansion for PVC (3.38 x 10-5 in./in./°F) is almost three times as high as for aluminum and six times as high as for steel. Thermal expansion and contraction have a significant effect on long straight runs of conduit or pipe.
Once you get it buried, the temperature will be fairly stable, and the movement will be minimized. What are the specs on the pipe you are using?
I’m not sure of the pipe specs offhand. It’s 8” schedule 40 pvc.
So burying it should eliminate the issue ? I am going to start burying it tomorrow. It is laying in a trench, which wasn’t easy to dig in that rocky soil.
A few pics of the turbines, penstock and weir.
/ Help! Micro hydro pipe expansion #19
Neat project. Some time back I remember looking at the NEC for PVC expansion fitting requirements. For a location with a 100° swing (conservative for some locations between Winter and Summer) you'd need an expansion fitting in each stick of pipe. Burying the pipe might help.
I've been involved in some piping systems where the changes in the length of the pipe due to temperature change required anchors and guides in addition to the expansion fittings to ensure the movement happened where it should. Expansion loops were installed in some piping systems as well.
An excavating contractor once told me he dug a trench for a farmer for a water line to an outbuilding. They used a coil of black poly pipe that had been laying in the sun. The farmer did the connections and they backfilled the trench. The pipe contracted as it cooled and ripped both ends loose.
/ Help! Micro hydro pipe expansion #20
Looking at your pictures, the first thing that jumps out at me is the lack of purple primer. PVC pipe needs to have the purple primer to soften it so the clear cement will melt the two pieces together. When this is done, the joint is stronger then the pipe, and all your breaks will happen in the pipe, or at a T.
All the different colors and types of glues are pretty much worthless when dealing with PVC under pressure. They work OK for gravity lines, but even then, where I live, you will not pass an inspection if your drain lines do not have purple primer showing at each joint.
Here in East Texas, all water lines that have a decent amount of run will be slip jointed and not glued together. When the soil is wet and it freezes, it moves. When it thaws, it moves. The pipe needs to be able to slide in and out of itself so it doesn't break.
Since your line isn't under any significant pressure, you can probably get away with just a couple of slip joints. I've never worked with 8 inch pipe, but I'm sure that there are slip joints available for it since it's a common sized pipe used for city supply lines.
If it leaks now, it will only get worse if it's buried.
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
2007 Acura TSX Sedan (A61569)
2007 Acura TSX...
2024 Kubota SVL97-2 Compact Track Loader Skid Steer (A61567)
2024 Kubota...
2017 Ford F-150 Ext. Cab Pickup Truck (A61568)
2017 Ford F-150...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
2019 Chevrolet Cruze Sedan (A61569)
2019 Chevrolet...
