Draft & Pressure Shift levers
   / Draft & Pressure Shift levers #1
Pamm
FL
Massy
Pressure Shift lever won't move as it is rusted up. The draft lever works well. I put WD 40 on it and a pipe wrench but no luck. Does anyone think it may just be rusted bad and I need to heat it? Or what I can check?
   / Draft & Pressure Shift levers #2
Welcome to TBN. A little heat couldn’t hurt. Hopefully it’s just rusted and can be loosened up working on it externally.
A new tractor for you I take it?
Thanks I'll try that this weekend to see if it moves any. Up Down lever has always worked fine, I never used the other one it has always been stuck
OK That worked after a lot of heat and 30" pipe wrench and a man helping. I was told that that lever has not moved is over 30 years. But now I can't read the writing on the plate to see where I need to run theat leaver. Who has an old emblem like that or a pic so I can see it (175 Massy )
   / Draft & Pressure Shift levers #5
Here is a photo
Thanks I can read part of it. I need a new sticker who ever has those. I really don't know where to leave that lever now. I noticed that in some places it changes the motor sound
   / Draft & Pressure Shift levers #7
If the inner (position or lift control) lever is all the way back (turquoise) color in photo, the pump will run constantly against the relief.
From England:
OK so when do I do that and is it best to not run constant?
Thanks that a long way for e-bay, i'll see if any in the states
   / Draft & Pressure Shift levers #10
Yes, don't do that. Raise to just before that
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
TRUBILT SKID STEER QUICK ATTACH PALLET FORKS (A51244)
TRUBILT SKID STEER...
2018 ford explorer (A50324)
2018 ford explorer...
UNUSED AGT KRW23 WHEEL LOADER (A51243)
UNUSED AGT KRW23...
KUBOTA RTVX900 (A51243)
KUBOTA RTVX900...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50774)
ALL TITLED ITEMS...
