Best way to get diesel into the tractor?
   / Best way to get diesel into the tractor? #61
One of the reasons I love ground level fueling
   / Best way to get diesel into the tractor? #62
That's what I do. Exactly. Same container and same spout. I do put a piece of padding on the hood so it doesn't eat up the paint so bad...wish I'd done so years ago.
   / Best way to get diesel into the tractor? #63
   / Best way to get diesel into the tractor? #64
I got a 12v pump, hose, and nozzle kit from NT. Was pricey but works a charm mounted on a 55gal drum with a little AGM battery.
   / Best way to get diesel into the tractor? #65
To fill my lawn mower I put a T in the gas line on
my old Dodge pickup with a ball valve and a long
hose. When I needed gas for the lawn mower just
push lawn mover over my truck start truck open
valve and walla gas tank full.
For diesel I have these 2.5 gas oil plastic cans and
will be using them as they come with the oil and a
lot lighter than 5 gal. I have no problem lifting the
5 gal can of diesel to put on top of the hood and I
also have a battery operated pump where I put the
5 gal of diesel on tire and let the pump work.
willy
   / Best way to get diesel into the tractor? #67
I bought a "Shaker hose".
Flotool Shaker Siphon - 6Ft., 3.5 GPM, Model 10801
I put the fuel can in the loader bucket, raise it above the tank and siphon fuel into the tractor.
Someday I'll have a 30 gallon tank and put it overhead in the shed, so that I can just turn on the valve and it will run into the tank.
   / Best way to get diesel into the tractor? #68
You can do it cheap and do it again in few years, or you can spend $250 - $350 and do it once!
Each to his own.
   / Best way to get diesel into the tractor? #70
The easyest way is to get somebody else to do it;)
willy
Two Pairs of 8ft Fork Extensions (A53421)
Two Pairs of 8ft...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
2008 JLG 2630ES ELECTRIC SCISSOR LIFT (A52705)
2008 JLG 2630ES...
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
UNUSED RAYTREE RMRB72 - 72" POWER RAKE BUCKET (A54757)
UNUSED RAYTREE...
