Mahindra 60" belly mower
/ Mahindra 60" belly mower
hows the quality of cut on these? is blade tip speed higher then residential lawn mowers?
/ Mahindra 60" belly mower #23
Blade tip is 17,350. Don’t know how that compares to a residential mower. I think the cut is good and I mulch mainly because I hate raking leaves in the fall.
/ Mahindra 60" belly mower #24
I flip mine over to remove the blades for sharpening. I have hooks on my bucket and use a couple nylon slings to lift it. Flipping it makes it easier to block the blades to torque the bolts. Think it’s like 150 ft/lbs.
I cheated when I pulled the gearbox and used a chainfall and put the deck on a couple of horses.
Same here. Takes 5 minutes to slide mine out from under my Kubota. Then I pick it up with the loader and leave it sitting on the ground but hanging vertical so I can access the blades and underneath. Piece of cake. I love the MMM for everything but tight trimming.
/ Mahindra 60" belly mower #25
Here is some hard learned information on that there belly mower gearbox Little Bill...
/ Mahindra 60" belly mower #26
Has anyone had a problem loosening the drain plugs or changing or adding fluid? I think I stripped the heads on those recessed bolts
/ Mahindra 60" belly mower #27
Yes. If you are talking about the fill plugs they can be a bugger... If they are stripped you may have to add a LITTLE heat from a torch and/or use an easy-out. You can get replacement plugs.
As for adding fluid- thats a trick to get the gearbox level in whichever means you can so that it is even with the middle of the shaft. I use a piece of nylon tubing on a large syringe type lube tool to squirt in the oil.
/ Mahindra 60" belly mower #28
Thanks for replying. I was able to work them free by pounding a star socket into the holes and after ALOT of force I managed to get t2 of them out. I was able to find replacements at a local hardware store. I did add the fluid and yes that was a challange as well.
Just buy this, I will leave it at that. I have this for both screws and sockets, i use to snap constantly because we are in rust belts. these tools i have greater then 80% success rate walking the bolts out. as long as you have the clearance to get it in there.
this sends a impact down the entire screw and bolt, not just the head like a normal impact
/ Mahindra 60" belly mower #31
Sorry I just saw this. I managed to get it out by tapping a star bit slightly bigger then the one it takes and slowly got it to lossen. But I will definetly look into this. Thanks
/ Mahindra 60" belly mower #32
Thank You. disappointing to hear the gear box has to come off.
I realize these threads are a couple of years old, but I wanted to hear/see the directions for removing the gearbox. I have the same MMM on my Mahindra Max 24, along with the manual, which by the way does not show how to remove it, step by step. If anyone still needs the manual on this, I'd happily provide one. I can copy it into a PDF of same.
I will take it. I still haven't messed with mine since I have a normal mower. Appreciate the offer
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
Ratchet Straps (A62183)
Ratchet Straps...
Preliminary Listing / Full Catalog Coming Soon! (A62180)
Preliminary...
2006 Toro SandPro 2020 Bunker Rake (A61572)
2006 Toro SandPro...
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
2024 DODGE TRUCK BED (A63569)
2024 DODGE TRUCK...
