Starting my bridge!!
/ Starting my bridge!! #161
FTFY
Put a couple angled pieces in that handral and you have essentially built a 40" tall truss....which will be ALOT stronger than just the 2x6 bottom tube. Maybe to the point of needing nothing more
I kinda figured that’s the route to go.
Any particular orientation for the “kickers”?
I’ll most likely notched the ends of the kickers to lap onto the vertical tube. Lots of surface to weld set up like this.
/ Starting my bridge!! #163
The railing doesn't have to be that strong. The end supports need to be able to carry whatever weight you're transferirng to the tension rods (easy, that's not much) and the railing needs to be sturdy enough in compression not to buckle. Neither of these are dealing with a multiplied force like the tension rods.
A couple of wood 2x6's is probably sufficient in compression if you can stiffen them, that's why I suggested that if you had more of the 2x6 tube that filling it with concrete would stiffen them. If the end supports are well anchored that would also help, but really this is the lightweight part of the design, just put something between the uprights that'll stay between them.
if the king truss is used above the deck you are making the railing a main structural element. Below the deck the deck is the compression member. You are also inducing a lot of stress in the end post connection. In former career I was lead bridge inspector
/ Starting my bridge!! #164
Hard to say.
Upside down V.....going from bottom of middle post out to the top of the two end posts puts that angle brace in tension. Angles the other way going from bottom outside to top of middle post puts them in compression.
Gut feeling makes me think either will be fine....and the ultimate yield strength of the structure will be limited to localized connections of the thin wall tubing.
Hard to say.
Crappy mark up I know.
I’d notch the ends of the angle and have then lay on the face of the post. That would give me plenty of surface to weld too
/ Starting my bridge!! #166
The king truss doesn't even have to exist above the deck when using the tension rods. It serves *zero* purpose in the tension system. The only reason to have it in this bridge is as a brace for the top rail itself.
If the end posts were sturdy enough and you could otherwise guarantee that they won't fall over, you don't even need the top rail either; all the tension system needs is for the tension rods to be pulling up and out.
It kinda reminds me of another bridge...
you can see the end posts, which are being kept vertical by tension cables pulling from the ends to the land. Where's the king truss and rail?
In fact, the bridge we're discussing here - with tall end posts and a tension rod pulling up on the middle - is essentially the most basic of suspension bridges. The bridge itself is strong enough not to need suspension every 4" instead it's only suspended from a single point, the middle.
Since the end posts aren't braced otherwise, we need the railing as a structural component, to keep the end posts from collapsing inwards from the horizontal component of the tension. If you set them up some other way (like use a telephone pole sunk way deep, or set up a really long H-brace away from the bridge - which is basically a tension rod arrangement too) so that they won't be pulled towards each other, you can eliminate the top rail too, but it's nice when bridges have that railing to keep an eye on as you drive over the bridge too. Then, the "king truss" is just something that keeps a 20' rail from bowing downwards.
/ Starting my bridge!! #167
Yes the bridge can be totally redesigned to get rid of king post, but you are making the structure a lot more complicated and harder to build safely .
in a suspension bridge the towers are in compression and have relatively equal forces acting on each side
the bridge under discussion is truss design not suspension design
/ Starting my bridge!! #168
It's not a re-design; he brought up using a cable for tension half the thread ago; it was refined and calculated out shortly thereafter. Turning the bridge into a tressle is a redesign he doesn't need.
We're not talking about a truss design. The end posts for tension rods are similarly in compression; since they don't have equal forces on each side, that's why there's the rail between them.
Now, if you go making that rail do more work than just compression by adding diagonal trusses between it and the bridge, *that* is some serious complication and I'm not going to touch that with my math. I'd stick with the end posts, a simple beam between them that doubles as a hand-rail or just visual rail, and a couple tension rods. Very simple math there and a tenth the cutting and welding.
After school on the playground by the swings?;)
Wondering if I should start a thread for my elevated tiny house when that gets built. (Of course I will)
I’m reading and trying to digest all the stuff you guys post.
My thoughts…..
A “truss” design seems to make the foundation less important.
I’ve got to build some kind of railing so it seems the truss is a 2 for 1 kinda deal.
I’m not afraid to cut/weld/fabricate stuff. Simple is always better though.
Can I eliminate the top tube, replace with angle iron and a wood cap?
If what I’m reading you guys are posting it seems that my be an option.
/ Starting my bridge!! #170
My thoughts…..
Making the truss into your railing, introduces lateral stability issues that should be accounted for. Can lead to sudden failure of your bridge. These calculations are not read chart and get your member type designs.
king post under bridge is a much simpler design for stress and loading. your deck doubles as bracing for lateral loads in this design.
ning
your design adds a lot of new forces that must be accounted for to safely cross the bridge. It is not as simple as you think it is
/ Starting my bridge!! #171
Truss or tension rod both have the same foundation needs, unless you're sinking an end post into the ground (unnecessary).
Either (right side post in drawing) there needs to be a member between the two upright end posts that can stand your load in compression, or (left side post in drawing) a diagonal brace serving the same purpose (can still have a light handrail).
Neither affects the foundation; all load on the foundation is as it was when you started this thread. Anchor one end of the bridge, maybe both ends (one side have slotted anchors? idk), with some way to account for thermal expansion of the bridge and it flexing under load.
> ning
I'm wearing a parachute
> ning
I’m planning to pour a concrete approach/abutment on one side for sure.
The other side is more difficult to get concrete too. I could fab a chute to get concrete across the bridge. May end up being some old Schlub mixing it by hand…….
Maybe some sort of grade beam/small slab on the far side with some slotted tabs for anchors in the concrete.
I can definitely duplicate either or both sides of your pic @ning
/ Starting my bridge!! #173
For a short span bridge you don’t need to worry about expansion at you abutments
Back at the farm by myself with my work truck, welder, a truck full of steel “stuff” and a decent weekend weather wise to work on the bridge
Was chatting with a fellow ironworker today and my bridge came up.
He and another guy built a bridge to support a 11,000 pound truck.
They made “trusses” for the spans similar to what I’ll do.
He recommends cutting the end posts short and “bowing” the railing when I weld it. Then weld in my bracing.
Any thoughts on this idea?
/ Starting my bridge!! #176
Can you post a diagram of your planned trusses?
Bruce
This is pretty close.
Some angles on the ends going down to the stringers
2021 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2021 ASV RT-25...
2004 INTERNATIONAL RA027 4X2 S/A DAY CAB TRACTOR (A59911)
2004 INTERNATIONAL...
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
2015 John Deere 8345R (A64119)
2015 John Deere...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59911)
2016 FREIGHTLINER...
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
