Crimping hydraulic hoses at home?
   / Crimping hydraulic hoses at home? #1
etpm
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Can hydraulic hoses be crimped at home using a vise or something similar and dies? I would really like to crimp my own fittings on 1/4 one wire hydraulic hose. I looked but did not find an inexpensive way to do this. But with all the DIY knowledge on this site I am hoping someone here knows how to do this.
Thanks,
Eric
   / Crimping hydraulic hoses at home? #3
Got a bottle jack hydraulic press?
glean more insight here:
Thanks for the links, I'll look at them tonight. I do have a machine shop so I could make rings.
Thanks,
Eric
   / Crimping hydraulic hoses at home? #6
I've never even considered DIY. There is a business in Spokane - House of Hose - that will do anything I need.
   / Crimping hydraulic hoses at home? #7
Thanks,
Eric
I have three cranes. One of them lifts 30,000# 70 feet high. Everything on it is a non crimp field fitting. Other two cranes are smaller and have field fittings also. So I'm fine with screw on field fittings.
   / Crimping hydraulic hoses at home? #8
I've used quite a few field fittings too, but if a version exists for 1 wire hose (more flexible) I've yet to find it. I worked instrumentation the last 34 years before retiring and have tubing benders up to 5/8, so if I need sharper bends I'll just do steel tube, I have JIC swage lock fittings for that... Steve
   / Crimping hydraulic hoses at home? #9
The profit margins for making hoses aren’t that good and small hoses are cheap anyway. Just have a shop make them. A hose machine has significant clamping pressure. There’s no way a vice would work. A shop press could be made to work but you would need several hundred dollars in dies and plates to make it work.
   / Crimping hydraulic hoses at home? #10
If I had thousands of dollars to burn on bulk hose and fittings I'd have no trouble spending several more thousand on a saw, crimping machine and dies. Very cost effective for making maybe a couple of hoses a year. Think of all the time I could save calling my supplier, ordering the hose, and going to pick it up the same day.
LAMAR 20 T/A TRASH TRAILER (A50854)
LAMAR 20 T/A TRASH...
2019 BOBCAT S770 SKID STEER (A51242)
2019 BOBCAT S770...
2005 KOMATSU PC400LC-7L EXCAVATOR (A51242)
2005 KOMATSU...
71068 (A49346)
71068 (A49346)
2016 HITACHI ZAXIS 210LC-6N EXCAVATOR (A51242)
2016 HITACHI ZAXIS...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
