Crimping hydraulic hoses at home?
   / Crimping hydraulic hoses at home? #1
etpm
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Can hydraulic hoses be crimped at home using a vise or something similar and dies? I would really like to crimp my own fittings on 1/4 one wire hydraulic hose. I looked but did not find an inexpensive way to do this. But with all the DIY knowledge on this site I am hoping someone here knows how to do this.
Thanks,
Eric
   / Crimping hydraulic hoses at home? #3
Got a bottle jack hydraulic press?
glean more insight here:
Thanks for the links, I'll look at them tonight. I do have a machine shop so I could make rings.
Thanks,
Eric
   / Crimping hydraulic hoses at home? #6
I've never even considered DIY. There is a business in Spokane - House of Hose - that will do anything I need.
   / Crimping hydraulic hoses at home? #7
Thanks,
Eric
I have three cranes. One of them lifts 30,000# 70 feet high. Everything on it is a non crimp field fitting. Other two cranes are smaller and have field fittings also. So I'm fine with screw on field fittings.
   / Crimping hydraulic hoses at home? #8
I've used quite a few field fittings too, but if a version exists for 1 wire hose (more flexible) I've yet to find it. I worked instrumentation the last 34 years before retiring and have tubing benders up to 5/8, so if I need sharper bends I'll just do steel tube, I have JIC swage lock fittings for that... Steve
   / Crimping hydraulic hoses at home? #9
The profit margins for making hoses aren’t that good and small hoses are cheap anyway. Just have a shop make them. A hose machine has significant clamping pressure. There’s no way a vice would work. A shop press could be made to work but you would need several hundred dollars in dies and plates to make it work.
   / Crimping hydraulic hoses at home? #10
If I had thousands of dollars to burn on bulk hose and fittings I'd have no trouble spending several more thousand on a saw, crimping machine and dies. Very cost effective for making maybe a couple of hoses a year. Think of all the time I could save calling my supplier, ordering the hose, and going to pick it up the same day.
International 475 14 ft Disc Harrow (A52128)
International 475...
2017 Ford Explorer (A50324)
2017 Ford Explorer...
Texas Built 25' Stand Alone Inline Feeder (A50515)
Texas Built 25'...
2007 Astec RT-360 Ride-On Trencher Backhoe (A50322)
2007 Astec RT-360...
2019 Doosan DX225LC-5 Excavator (RIDE AND DRIVE) (VERY NICE) (A50774)
2019 Doosan...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
