Starting my bridge!!
/ Starting my bridge!! #61
Did you ever say what you were going to use for decking?
And curious why you chose 2.5' spacing.
Car trailers and even some equipment trailers have cross members on 24" spacing......and that seems to work pretty well with 2x8 or 2x6 treated lumber. But not sure how 30" spacing would work.
IF you have some hardwood sawmills in the area.... full 2" rough sawn white oak is alot stronger and lasts just as long as treated pine
/ Starting my bridge!! #62
Been following this build as I have a very similar landscape on the back of 20A and eventually want to build a bridge that would hold about 7000#. If anything my creek might be like a 2ft wider (longer span for the bridge). You had mentioned "I" beam...I have an old 14'x70' mobile home that is basically garbage except for the steel I beams under it (its an old one with the 1-1/2" outside walls). Those I beams are about 12" to 14" high and the steel in them is 5/16". Could I repurpose those I beams to build a similar bridge that would hold the weight I need?
There is no guessing when it comes to steel and sizing.
I cant work off of "about 12" or maybe 14" tall".....or "maybe 2' longer span"
Need to know specifics. Need to know exact dimensions of I-beam, exact span.
Then on the typical mobile home I-beams.....bracing is key. Because they are so tall and thin.....they naturally want to flop over on their side.
So...."can" a 14x70 mobile home frame be made to work.....YES it can. But can it also fail if done/braced improperly.....also a yes.
And dont take any of this as gospel. This is just an internet forum and the advice you receive is worth exactly what you pay for it
/ Starting my bridge!! #63
Thank you, I know there would have to be some kind of engineering mathematics etc. Im not ready to build it just this year, its project Ive been thinking about just so that I don't scrap the whole mobile home and throw away good steel. I do understand what you are talking about as far as needing more information etc. Is there a book on basics for the engineering math on bridges etc.? Not sure I worded that right but reference materials for bridge building that YOU would recommend a person read before starting any bridge project? Thanks for your input, much appreciated.
/ Starting my bridge!! #64
I built a bridge at my old farm. 16’ span, 6’ wide for ATVs and equipment and horses mainly. Built it out of 4x6 treated lumber, four of them spanning the creek, resting on 6x6s, topped with 2x6 treated boards. It was solid, weighed more than the moon and never even flexed with the heaviest loads I drove over ( ATV and trailer)
Then we had ‘that’ storm! I’d never seen the bottom like it. My shooting range was two or three feet deep in fast running water. Two weeks later it had dried enough to get down there. My bridge was gone. It was thirty yards down stream, up the bank and wedge between two trees.
And that’s where it stayed!
Anchor your bridge down if there’s even the remotest chance that area can flood!
Looks great BTW!
/ Starting my bridge!! #65
Great project. Sometimes you can purchase a Highway Trailer flat bed 40-50+ feet long and cut off the undercarriage. Once you get it across with Dozer or crane, lay the ends on a few Railway ties. Done.
/ Starting my bridge!! #66
I really wanted to comment as soon as I saw this post, but I made sure to read the whole thread all the way through first.
I understand why you're building this the way your are. You're a good welder and have access to free materials. Makes sense. I won't argue with your design. Others more knowledgeable than I have already rung in on that. And time will prove it out one way or the other.
My only question is whether or not it would have been feasible and/or advantageous to put a culvert pipe in there and fill gravel and dirt over it? Just guessing maybe a one 2', a 3', or two 2' culverts? Just asking. Maybe the pipe is too expensive. Maybe the span is too far.
Best of luck with it. Looking forward to more updates and photos!
Bill
/ Starting my bridge!! #67
Great project and thanks for sharing. Nice work so far!
But your design gives me great concern, so heres 2 cents you didn't ask for.
You want to drive a 6000 lb f150 across a 7' wide bridge? That sounds terrifyingly narrow. I made sure to get just over 9' wide for mine, which is very comfortable for tractor. Still haven't tried my truck across, but the weight is the same as my fully loaded tractor.
Furthermore I have to defer and agree to LD1's gut call on your designs capacity. It's a pretty long span for such little metal! At the very least it will probably be very bouncy (no big deal) but my fear would be that it taco's in half as soon as you put 3500 lbs in the middle of it (truck front axle, or tractor front axle with heavy loader bucket load, for example).
I don't think adding some design bandaids like cables or a little pole truss railing on each side is going to give you the capacity you were hoping to have. Maybe I am completely wrong here, but, beware.
I really wish you had put concrete foundations down to frost line. A ground contact 6x6 should stay mostly intact for a while, but eventually your abutments are probably going to be getting soft, collapsing into the mud, and/or frost heaving to funky angles.
You are building a kickass 4-wheeler bridge, but for a pickup truck? Doesn't look like it, sorry. I like the other notions before my post, to maybe just lay a used trailer deck across what you have going here already, to add a lot of extra strength.
Carry on and please keep us updated!
/ Starting my bridge!! #68
Just google steel beam deflections and steel beam stress.
You will get all kinds of formulas......distributed loads, point loads, etc.
But all common steel has given properties. All common I-beam shapes, Channel, tube, etc.
Its simply math from that point. The key spec you are looking for to calculate deflection is called moment of inertia (i⁴) You can get some I-beam specs here W-Beams - American Wide Flange Beams
The LIGHTEST 10" I-beam they list is a W10x12. Meaning 10" tall and 12lbs per foot. And has a moment of inertia of 53.8
For simple deflection with a load at mid span.....(WLᶟ)/(48Ei⁴)
In other words......weight times the length in inches cubed.....divided by 48 times modulus of elasticity times i⁴
Modulus of elasticity of steel is 30,000,000
So, with 3000 pounds at the middle of a 22' span:
(3000 x 264 x 264 x 264)/(48 x 30,000,000 x 53.8) = 0.712" of deflection.
You should try and keep deflection under L/360. So 264"/360 = 0.733 So a pair of those beams in theory is good to a little more than 6000# total at midspan with a point load.
But with steel members that arent common.......or listed anywhere.....for example if your trailers I-beams arent actually I-beams but rather plates of steel welded together.....or in the OP's case of maybe stiffening tubing with cable or strap or re-bar.....makes it VERY complicated to calculate the moment of inertia. And therefore very difficult to assign a proper load value. Because alot more things come into play other than just raw steel. For example.....quality of the welds, enough weld contact area, bracing, etc.
A fun little tool/calculator I downloaded years ago so I dont know if its still avalialbe is called BeamBoy. It calculates all the stress and deflection for a given shape. And they have alot of shapes already stored in the program with the relevant parameters.
So in the above example of the 22' span and W10x12 beam it looks like this:
/ Starting my bridge!! #69
That pesky “hiring” word…….
My neighbor has a couple excavators but I hate imposing.
The chute idea isn’t bad…….
I do have a teenage boy with friends and some wheel barrows.
Use a wheel barrow. Contractor grade 6cf will move a yard in 5 trips. No brainer with strong boys with weak minds. Redimix truck chute will reach over 1/2 way across the bridge. Screwing around with chutes or excavator would take longer than the wheel barrows
/ Starting my bridge!! #70
Looks great BTW!
My neighbor had a wooden bridge to drive their cars across that had oak tree trunks for beams and heavy oak boards from the sawmill. It washed downstream into my concrete bridge in a bad storm. I guess wood still floats even if it's heavy as blazes.
/ Starting my bridge!! #71
Brings me back to my college days, statics and dynamics class.
So glad this is all in books/online for lookup now.
The formulas always gave me headaches deriving them.
/ Starting my bridge!! #72
Thank you, wow, loads of info on that reply. I love math :) but some of this might be beyond me at the moment, thats how a person learns. To me, reading your reply, its apparent that even with deflection and load capacity, it all depends on how good and strong the ends are supported on the beams and where it would be necessary to have like a frost foundation (footing wide enough to keep things stable) and support wall at each end because the load (weight) can shift and put more weight on one side or in front or back etc. Another poster just mentioned why not use a culvert, of course a culvert would have to be sized correctly and then lots of fill built up around and over it. many things to think of, but safety should be the first consideration and without proper design, safety might not be there. interesting for sure.
/ Starting my bridge!! #73
Great Project! Hope you keep posting pics/progress.
Good luck!
/ Starting my bridge!! #74
Interesting build, enjoyed following this! Small streams have a habit of becoming much larger streams during a downpour. Be careful of putting stiffening structures under your bridge as they can serve to catch debris under high water conditions. Have you checked a FEMA flood map for your location? They are based on watershed area and topography plus assumptions on a 100-year rain event. If your bridges abutments are within the 100-year inundation area then water will get up to your bridge.
We have a creek in our front yard which I have long wanted to build a bridge over. When the power company upgraded the lines through our property I was given around 16 power poles, with the thought being to use some in a bridge. Then in 2021 we had two 100-year rain events and I saw the raging torrent our little creek could become, a bridge would would need to be 5’ or so above the bank, which makes this a major project with long approaches. Currently thinking about a draw bridge, using an aluminum bridge kit I found on line.
/ Starting my bridge!! #75
Yes, you have to look at the big picture and the structure as a whole. Cause even with properly sized beams a structure can fail if improperly supported and braced.
BUT......it all starts at the beams. Start with beams that are too small for the load.....and it dont matter how its braced or if you have hoover dams for supports on each end.....the beams will still fail.
/ Starting my bridge!! #76
In my barn thread I mentioned a bridge build and people wanted me to post when I was building it.
Todays the day!!!
Approx 20’ span
Approx 7-8’ wide
2x6 tubes for the stringers
A center 2x6 tube under the stringers
3x3 tubes for cross members
6x6 treated timbers for the “foundations” on each end.
End goal is to drive a vehicle across!
View attachment 786740View attachment 786742View attachment 786743View attachment 786745
Depending on the cost of course, but a Sea Can works good as a covered bridge as well. You just pour a cement footing on both sides for it to sit on. The only problem with the sea can is the width. Cars and pickups are good but flatbeds and trailers are quite often too wide.
Thank you for sharing, free steel is always good.
Are you capping the hollow steel or rust proofing the inside?
Todays the day!!!
Approx 20’ span
Approx 7-8’ wide
/ Starting my bridge!! #77
With free steel, maybe add a couple more 20ft stringers to increase the section modulus out in the middle. “Overbuilt” is in your favor.
I may have missed it but never saw the wall thickness of that 2x6 tube. You might post it, or PM it to one of your engineer-members.
Or add the doublers above deck, like 6” high “wheel railings”.
They don’t have to bear out on the foundation, they do their job “out in the middle”. A 12” high section will increase the strength substantially.
The rounded tube corners will allow welding not totally overhead (for the 12” section suggestion). Maybe you can get help with any overhead welds, or just don’t post pics. Your other welds suggest that you can do it well, or can learn.
Consider padlocking a “post” in the middle it so you have *full control* that only ATVs can cross it if you’re not there.
Your deflection testing/measurement method with the string is good.
Write down the deflections/weight, in the future you can use the string method as a scale to weigh eqpt that crosses your bridge🤓.
Sorry if this sounds “critical”, but F150 kinda gives me the willies. I wouldn’t drive 7,000 lbs over that before a real confident deflection test. My gut suggests verification with 10,000 lbs (about 3x safety factor) right in the middle - would be good to allow one 3500lb F150 axle out in the center.
With testing comes confidence.
Whats the tractor weight?
/ Starting my bridge!! #78
2x6 tubes are 1/8” wall.
Outside tubes have a piece of 3x3x3/16 -20’ welded to them for the 3x3 cross tubes to sit on
There’s another 2x6 tube in the center under the 3x3 tubes
Tractor weighs approx 4000 pounds
I’m going to build this under each of the stringers out of 5/8 rebar. An Engineer “assisted” me with working out the idea.
I’ll probably also build 2’ or 3’ tall truss style railing on the outboard stringers.
Just about got the ok from the finance manager (wife) for some concrete to lock down both ends of the bridge. She hasn’t actually seen it in person yet!
I like to build stuff!
This is my 4th bridge on property.
A small 12’ long to walk across
B6216C85-AFFF-45D7-AA88-8763EF470895.jpeg644CFA80-5FCA-47B9-A59D-DC8C97264ACD.jpegF0B2BE2F-A5AA-4718-B8A0-E3F52293CC96.jpeg
A 3’ wide 25’ long to walk across
The first one I built
5’ wide 25’ long
Post in the center of the creek
ATV/foot traffic only
/ Starting my bridge!! #80
Looks like a fun project and lots of work put into it. I agree with the others about not having the substructure for a pickup-sounds like you are trying to remedy that. The footings/abutments are your biggest failure points. Using native soil is always sketchy due to sinking and erosion. Rock is king and having abutments out of the channel width and/or abutment protection is key. In general the bottom of your bridge should be 3’ above the 100year flood level. Most guys make their bridges too short to cut costs but it will always leads to failures of some sort. Eco blocks make great abutments and they’re about 25$. The other option is have you considered a log stringer bridge? If you have trees on your property or can get some you can make a stout ass bridge. We use them for fully loaded log trucks. Here’s a link https://www.dnr.wa.gov/publications/fphp_ins_temp_bridge_ex_plan.pdf
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
2007 Montone AD24465448 30ft. Tri-Axle End Dump Trailer (A61573)
2007 Montone...
2015 HYUNDAI HX220L EXCAVATOR (A64279)
2015 HYUNDAI...
2014 Volvo Sleeper Tractor (A62679)
2014 Volvo Sleeper...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
2004 IH 5600I Snow Plow Truck (A62679)
2004 IH 5600I Snow...
