John Deere 6400 Water Pump replacement!
/ John Deere 6400 Water Pump replacement! #1
mastercraftka
Hondo Texas
1993 JD 6400 4wd
Anyone replaced the water pump? Do I have to pull the whole front end off first? Not much on Youtube.
Any pointers?
It is dripping after you shut it down. Don't see it leaking while its running.
/ John Deere 6400 Water Pump replacement! #2
Consider rebuilding it verses replacing it. They wanted $650 for a rebuilt one at the JD dealership - not that Id go there unless I had to - but the rebuild kit was only $53.
Did you remove it yourself?
/ John Deere 6400 Water Pump replacement! #4
Yes
It will most likey be fairly integrated into the front of the engine, even so its better than having Jd come out and service it
/ John Deere 6400 Water Pump replacement! #5
Yes
Ya looking like I have to take the front end off and that doesnt look appealing to me.
/ John Deere 6400 Water Pump replacement! #8
I recently replaced the water pump on my 2005 jd5105. Dealer wanted $866 for a new one. I found a new aftermarket pump for $230 total on Amazon. I wrestled with the job for about 3 hours total. I’m getting old.
trying to revive this we haven't fixed it yet. Only video I could find online was horrible and basically said you must remove the entire front of the tractor radiator and everything to access the pump
/ John Deere 6400 Water Pump replacement! #10
Not planning to attempt it until after you find a video that shows how without removing the radiator?
no it is a small leak and obviously needs to be done it is still working not overheating. Just trying to get it planned and the plan of attack.
2022 JCB Fastrac 4220 217HP 4WD Agricultural Tractor (A66734)
2022 JCB Fastrac...
2019 John Deere XUV 560E (A64912)
2019 John Deere...
Whisperwatt 125KW DCA-125USJ Gen Set (A64911)
Whisperwatt 125KW...
Detroit Diesel 4 Cylinder Power Unit (A64912)
Detroit Diesel 4...
John Deere 5320 (A64911)
John Deere 5320...
2021 Kubota U25 (A64911)
2021 Kubota U25...
