New Owner Need Draw Bar
/ New Owner Need Draw Bar #1
Mitch2023
Yanmar 336D
Hi, first post here. We just bought a new to us 336D today which will be delivered next week. It doesn't have a draw bar. The seller said he would look to see if he has one but I don't have much faith in that.
Can a new one be purchased or would it need to be fabricated? I don't want a 3 point, just a below the axel. I guess I need a pin also. Are there any other parts involved
/ New Owner Need Draw Bar #2
Welcome to TBN...enjoy.
Maybe DRAWBAR can help.
/ New Owner Need Draw Bar #3
Most are just flat bar steel stock and not that hard to fabricate with a hack saw and a drill press once you buy the right size bar stock. Then purchase the right size hitch pin from tractor supply or the like
/ New Owner Need Draw Bar #5
Mitch,
Welcome.
Do you live near any farm stores like Tractor Supply, Rural King, Farm and Fleet, ASC, or the like. You can pick one up really easy there. These things weight a bunch, so having it on-line ordered+shipping would be painful.
Most stores sell them in black or red. So, for a Yanmar either works great.
Here is mine from Rural King,
Do you need FREE PDF manuals, we got them at the Yanmar Tractor Owners Group here,
/ New Owner Need Draw Bar #6
I think the OP is looking for the hitch ball tongue under the PTO in your picture. If he has a receiver mount there easy/peasy. If not, I think he is looking for what he needs to fab up for attachment. If the OP is looking for the 3pt drawbar, maverick just gave the answer.
/ New Owner Need Draw Bar #7
Tractor Supply Company (TSC) routinely stocks rear/center drawbars.
/ New Owner Need Draw Bar #8
Ah, so he is really looking for the trailer drawbar then.
Thomas did provide the link for that, however, Yanmar uses two types for the YM series. 1. round tube drawbar 2. flat like many of the Deere models.
/ New Owner Need Draw Bar #9
This is the correct part number for the 336. You can view the page in the 336 parts manual. 194275-75210-X
/ New Owner Need Draw Bar #10
I don't know if this is universally true but I've seen only round drawbars on the gray market Yanmars, and only flat bar stock on the US versions - like this 336.
Wow, I didn't anticipate so many replies so quickly. Mine has a rectangular slot and a hole for a pin. When it is delivered which may be tomorrow now, I'll get under it and take some measurements. If I use bar stock the only issue would be the size of the hole to drill.
Yes, there is a Tractor Supply not to far away. I will check that option.
Thanks for the parts list and part number. I will call Hoye and see what they have to say.
I need to get an operators/maintenance manual. I see Hoye has those. What items do I need to service? Filters, O rings etc. I see fuel filters listed but not oil filters.
Thank you for the help.
/ New Owner Need Draw Bar #12
I have had a 336D for about 33 years. Good, solid little tractors.
/ New Owner Need Draw Bar #13
This works well esp. with the Yanmar 2000. Use a couple different Trailer setups. I made it easy for both type of Hitches. Many Yrs ago but I believe TSC.. Super cheap 25$ maybe!! I did put the getto rig on it for when I use the trailer hitch. Keeps the Bar from tilting. Old Lawn mower blade.
/ New Owner Need Draw Bar #14
Nice, and Ive done something like this prior too. The only downside is, the weight limit ability is on the lower 3PT arms whereas on the bottom of the rear axle to take a much higher load.
I have a 14,000 loaded trailer to move seasonally. So easy for the Yanmar to hook up and go.
With the smaller garden trailers, the drawbar 3PT lower arms work well.
/ New Owner Need Draw Bar #15
Free manuals at,
/ New Owner Need Draw Bar #16
The only problem I have is not weight but Tongue weight. This Double Axle 3g Lbs. trailer is great. But!!! the small single axle garden wagon you have watch out and not get the weight behind the 1 and only axle. I've Dumped it quite a few times. The 3Pt. arms Will lift Weight but won't hold them down.
The seller delivered our tractor today! It sure is pretty. I'm going to hate taking it out in the mud. It's wet today, but when it dries I'll take a picture and post it.
/ New Owner Need Draw Bar #18
I use mine to move hay wagons into the 14,000-lbs range.
Sometimes 2 wagons at a time like this. Low and slow. PS 3, range 2.
/ New Owner Need Draw Bar #19
Bails and Barns Nope!! if I had livestock I'd go out of my way not to deal with them compared to Rolls. :confused: a few as a kid.......
