Cracked head?
/ Cracked head? #1
wep0520
Calhan Co
1947 John Deere B
I have been messing with this satoh s370d for 3 months. I got it at an auction with loader and rear blade fir $675. I dont know the year or how to find out the year and they didnt either. The tractor sat in a field long enough for the wheels to get buried 1/3 of the way. The only time i have gotten it to start it was over 60 deg out using wd40. Compression was at 300 and 280. I replaced the pistons(1 had a broken ring groove) now compression is at 350 but should be higher. Question, I have been told that if someone used starting fluid it could have cracked the head. Will a cracked head cause low compression? When i have had it running it wasnt mixing oil and antifreeze.
/ Cracked head? #3
If it’s not mixing oil and water, blowing bubbles in the radiator or burning water the head probably isn’t cracked.
/ Cracked head? #4
It probably has glow plugs, do they work? Is the fuel system and fuel clean? Do the injectors atomize fuel?
/ Cracked head? #6
you didn't mention if the glow plugs work. This engine needs to be glow plugged to start.
2011 CATERPILLAR 279C SKID STEER (A65056)
2011 CATERPILLAR...
PALLET OF TRASH PUMPS (A67714)
PALLET OF TRASH...
BOBCAT SKID STEER BUCKET (A64553)
BOBCAT SKID STEER...
2025 Rake Mini Excavator Attachment (A66734)
2025 Rake Mini...
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
KOMATSU D31PX Blade / C-Frame (A68134)
KOMATSU D31PX...
