Kubota or John Deer
/ Kubota or John Deer #41
On the way to the Yanmar dealer I stopped in a kubuta store and kicked a few tires. I looked at a L3301 I think it was. Right away I knew that was what I wanted. They wanted right at $31,000. That was taxes and the other little charges that they all add on and a new spreader box too. If I financed it you could take the $1200.00 rebate and also they had a $300.00 rebate on the secong implement for a $1500.00 total rebate. That knocked it down to somewhere in the $29,000.00 range. I was almost ready to do the deal when I asked him about used tractors, he didn't have any but he said they had a L2501 in delaware that only had 52 hours on it with three years warranty left on it. He showed me a pic of it and it hardly looked used at all, all the paint was still left on the bucket. I thought about it for awhile when he said, I'll have it sent down here so that I could take a look. 25hp vs 33hp is a lot in some respects but in my case I don't think it will matter much. I'm going to look at it good when it gets to town and decide then.
The L2501 is a great tractor. I highly recommend it.
Plus, if you need/want more HP, it is easy to modify for more power. My L2501 has been fantastic and is now producing 35 PTO HP with a Turbocharger kit.
Mike
/ Kubota or John Deer #42
I don't think even the biggest 3 series JD's will lift 1500lb to well, but will probably lift a full bucket of gravel good enough, with some 3 pt weight.
I went with the least hp in a bigger frame which isn't bad for dirt work, general mucking around stuff, wheelbarrowing dead cars around, lifting things. Not so good for running a round baler, and I wonder how it would do with a 7' snowblower since we are getting 1' snowfalls of dense snow this year.
Typically Kioti, Mahindra, Branson give you the lowest price/pound of tractor, and kubota and JD seem to cost the most/pound. But figure out what dealers are in your range, and then collect some specs and prices on the models you can get and see what you come up with as the "winner". Then take if for a test drive to see if its comfortable to you.
I would say its usually better to go bigger than you think, unless want to cut the grass with it, or get into some tight spots.
I know for a fact that my Deere 2038 will lift 1500 pounds to full height.
/ Kubota or John Deer #44
I’d be impressed to see a picture of that tractor lifting 1500 pounds at all and definitely to full height. Your ground level lift capacity at the pins is 1950 pounds and the 500mm forward capacity which is more representative of the true ability is 1360. The full height lift at the pins is 1120 and the 500mm forward capacity is 803. That specs pretty similar to my LA524 Kubota loader. The Kubota loader can lift 1200 pounds of concrete sacks with the bags stacked single file up against the forks to maybe 2ft high. If I had a lighter duty set of forks that was a better match to the tractor maybe I could lift 1500 pounds off the ground but full height isn’t happening.
/ Kubota or John Deer #45
You need to compare apples to apples (machines with like specifications) and answer that question yourself. Bang for the buck is highly subjective based on the features that each buyer values.
THAT is the sign of a GOOD Dealership, awesome service... and the sale isn't even made yet
/ Kubota or John Deer #46
I'm also a fan of Yanmar and a bit biased but I like what was said about a good local dealer. At your age you may not be servicing the tractor long. I know you are about the age my dad was when he could no longer service things well. He had some physical limitations though.
Consider that and check out the local dealers and perhaps buy the dealer service vs. the tractor. You won't often hear me say that either.
But to answer your question as you asked it, I would go with Kubota if all things, dealers etc. being equal.
/ Kubota or John Deer #47
Picked up my counter weight that is on a wood skid and put it on the pallet rack. I know it weighs just under 1,500 lbs. I have the light weight pallet forks. My system pressure was adjusted right at the upper limit by my dealer when he delivered the tractor.
/ Kubota or John Deer #48
Now that I think about it it was my 3720 that I used put the counter weight on the pallet rack. The 2038 will still do a lot of work for it's size.
/ Kubota or John Deer #49
No doubt it's a workhorse, but the 3720 makes more sense.
/ Kubota or John Deer #50
These guys have the newer version of my tractor, a NS4710 but with shuttle shift for $31k. https://www.tractorhouse.com/listing/for-sale/221185637/2022-kioti-ns4710-40-hp-to-99-hp-tractors
HST would be a bit more. This will lift 1500lbs pretty easily, still need a counter weight though. Depends what you are doing of course, and if you have a good local dealer that will get close to this price, but for equal dollars I'd get another 1000lbs of tractor. You can use good size implements and do most full size utility tractor chores. Downside is you may not be able to tow it as its probably 5500lbs with the loader and the average implement. Also its 6' wide if you are making walking trails in the woods.
/ Kubota or John Deer #51
I have one of each. The Kubota is 38 years old (L235) and the only problem has been to replace the water pump and maybe do that again in the near future. The front crankshaft seal also needs to be replaced. The JD (5055E) is is 13 years old and after disconnecting the cold start sensor it starts and runs well. I prefer the transmission on the Kubota. The machining of the internal gears seems to be much better. The JD feels like the gears were cast and then assembled without cleaning up the parts that mesh - this is only perception to try to describe the feel of the tractor. However, I got the JD for ground engaging and would have had to go to a 70 HP Kubota to match the weight of the 55 HP JD.
They are both good and reliable tractors. Be sure to drive each one, the layout of the controls and the amount of space you have are very important.
/ Kubota or John Deer #52
If you can get the L2501 at a good deal (say ~$20K) the frame and loader capacity is the same as the L3301 and L3901. Buy the turbo kit from Rdrcr for $3K to get the L2501 up to 35 hp at the PTO.
When I was selling Kubota and New Holland compacts, customers would come in looking, not sure what that wanted or needed. I would always have them operate different tractors to get a feel for the sizes and features. Had a couple come in one Saturday. They operated both a "B" and an "L" series. She ran "L" first and then the "B". When they finished, I asked them which one? She pointed to the "L". I asked why and she said that she sat higher on the tractor and could see the bucket was easier. I delivered it that afternoon. Also had a "dirt pile"
for customers to try out loaders. Nothing like "hands on".
Sounds like a solid good plan and a profitable one at that.
Mike
That's good to know. What would a kit like that cost and what does that do to a warranty?
/ Kubota or John Deer #55
Ask your Jane Dear dealer. Map closest dealers or parts suppliers. Consider proximity. Driving 3 hours for an air filter isn't a good use of time nor $. Stay a way from cheap parts imitation providers.
i know I'm lucky in some respects because I have friend that are older than myself that would not attempt half the stuff I have done around here. The thing is I know my limits and most folks when they get older they work smarter. My eyesight and hearing.....my wife calls it selective hearing, isn't as good as it once was and I have a few aches and pains in a few places I didn't have before but most of those were self inflicted from past incidents on a motorcycle or just doing dumb things that no normal human being would try to do.
All and all I get around pretty good but you never know when you'll get called home. I'm going to a furernal today for a friend of mine that was a WW2 vet that was 96 years old the day he passed. He was in the hunt club I belong to and he was the oldest active member of the club and hunted pretty much every day during the season, no matter how cold or wet it was he was there and would sit on his stand all day if they let him. I remember he told me the week before the season went out that this would probably be his last season but he intended to live every last minute he had left enjoying the time he had. He died peacefully in his sleep without a care in this world. I'll miss his ol war stories and the tales of his past hunts, they now will be only memories etched in our minds to remember him by.
Oh my the spelling police will be along in a little bit.:oops:
/ Kubota or John Deer #58
The L2501 really is a great tractor; with a loader they're a real jack of all trades type, almost anyone could find a place for it in their life.
The only thing in the lineup I like more is the forthcoming L2502.
/ Kubota or John Deer #59
GreenPartStore was my best friend when I owned my 1025R; Lord knows that United was about useless.
/ Kubota or John Deer #60
I love my L3560. If you found a used one, I would strongly suggest that you go at least look at and touch it. The stability is so much better than my B2650 I had. The B2650 could get tippy on side slopes while my L3560 (both with loaded tires) has been on such a side slope with the brush hog that I slid sideways down a hill and never lifted. I had the rears at the widest position on both. I also had a BX for a VERY short while and hated it. It was so tippy that it was just unsafe to use. Everything I did was in pucker-mode. The L3560 is a great machine and stability platform for it's size.
This is a Norstar Single Wheel Long Bed that is advertised as 1070 lbs, you can clearly see that it is far out front of my bucket.
3144 (A63117)
3144 (A63117)
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
2022 HAULMARK 14' T/A ENCLOSED TRAILER (A65643)
2022 HAULMARK 14'...
East Texas Gooseneck Trailer (A65563)
East Texas...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
