Starting my bridge!!
/ Starting my bridge!! #21
Thank you sir!!
Cut and notched 4 of the 6 cross tubes last night.
Cross tubes are on 2.5’ centers
Laid those 4 out this morning…..looking like a bridge!!
Gonna cut and notch the last 2 now.
Waiting till after 8 to fire up the welderD05FCD4E-EB7C-4DBB-9CB3-A1BE36252500.jpeg
/ Starting my bridge!! #23
Did you put gravel or something to keep moisture off the wood supports?
The bridge is going up pretty fast, looks good, thanks for taking us on the ride.
Welding is done!!!
Gonna set a string line on one side.
Throw some boards across and park both ATVs right in the middle and measure deflection……stay tuned 4600D044-DD48-49E3-BC0A-4B3BEE35D950.jpeg
Results……
Started with a bit of a crown….approx 1/8”
I’d say there’s an 1/8” between the string and the 2x4. 1/4” sag.
I have some 3/8 crane cable….I may make a “u” under each stringer and use a turnbuckle to “arch” the bridge
9623B83E-A033-455C-9EF4-E93E085CF98E.jpegE62B70B6-DE7B-4139-B3F7-FF3F0673A8A8.jpegE62B70B6-DE7B-4139-B3F7-FF3F0673A8A8.jpeg4DE49136-0EFD-4037-8944-D9C4D3D9950F.jpeg31293732-78B8-4B2E-9445-139DCCA6B972.jpeg
/ Starting my bridge!! #28
The traditional metal bridge construction method was to use a truss design. From what I read, much of the strength in a utility trailer has to do with the sidewalls acting like truss members and even there, a single solid rod added as a reinforcing member to the top of the sidewall construction can add to the carrying strength. Also, having some sort of sidewall members on a bridge would seem to add to the safety factor.
I plan on a railing/guardrail of some kind.
An inexpensive rebar guard rail could act as a truss.
Scootr
I was gonna build that under the span with cable/turnbuckles/piece of steel center span
Tighten turnbuckle-arch bridge
/ Starting my bridge!! #33
I did find these tubing pretty thin, figured three of them with the cross members would've been sufficient... The two ATV you are about 1200lb, the average 1/2 tone truck is around 5500lb... unfortunately I don't think I would want to drive one across...
Hence the cable/turnbuckle idea
I don’t NEED to drive a vehicle across.
Mostly a test of my skill to see if I can build so a vehicle can drive across
/ Starting my bridge!! #35
Will it look something like this when you are done?
Nothing new……
Except the churning in my brain!!
Most likely will put a concrete abutment on both sides. Rough math says approx 1-1.5yd should give me what I want. Getting it to the other side is my big challenge. Trying to figure where else to put more concrete. Minimum with no cartage is 3yds if memory is correct
Cable/turnbuckle idea will be used
/ Starting my bridge!! #38
Bu
Nothing new……
Build a wooden chute out of 2x6 sides and maybe a 2x10 for a bottom.
Hire a guy with an excavator or telehandler and a concrete bucket.
hugs, Brandi
Bu
hugs, Brandi
That pesky “hiring” word…….
My neighbor has a couple excavators but I hate imposing.
The chute idea isn’t bad…….
I do have a teenage boy with friends and some wheel barrows.
/ Starting my bridge!! #40
The mix will have to be real wet for a chute. You may have to push it down the chute otherwise.
hugs, Brandi
2005 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A61573)
2005 Dodge Ram...
2006 Hitch and Trailers Inc. 12ft S/A Utility Trailer (A61574)
2006 Hitch and...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
Zero Turn Mower (A59231)
Zero Turn Mower...
2006 CHEVROLET 2500 SERVICE TRUCK (A63291)
2006 CHEVROLET...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
