Anyone have a solution to eradicating moles ??
   / Anyone have a solution to eradicating moles ?? #41
my neighbor had some sort of mole extermination kit that hooked up to vehicle exhaust that channeled the fumes underground. i would not recommend, but a strange way. not sure how effective it was,..
   / Anyone have a solution to eradicating moles ?? #42
My friend had a worn out 1 cylinder motor on wheeled dolly. The exhaust was a longer flex tube he would put down the gopher hole. Said he often put oil in the gas to make it smoke more than it normally did.
   / Anyone have a solution to eradicating moles ?? #43
rekee / do you use these for gophers or moles or both? Gophers are herbivores while moles are mainly meat/grub/earthworm/insect eaters. I used to use these on gophers until I found effective traps. thanks
No gophers here so just using the poison peanuts for moles. I attempted to use traps in the past but they were ineffective.
iu
   / Anyone have a solution to eradicating moles ?? #44
We had a mole problem right after we moved in. I used trap and killed a bunch but there were plenty left to pretty much destroy my lawn. One of the scientists at the local CT AG station told me about Milky Spore. It kills the Japanese beetle grubs that the moles were after. It took about a year but the moles were gone.
I was also told the spore lasts about 25 years. Sure enough about 23 years later the moles made a comeback. Round 2 with Milky Spores.
About Milky Spores
   / Anyone have a solution to eradicating moles ?? #45
We had a cat that would catch a voles and once in a while a mole. We had it about 12 years in that time it caught about 3 moles.
   / Anyone have a solution to eradicating moles ?? #46
Maybe bc of your direct application of "liquids the moles might not like", you cat doesn't like it either and leaves tunnels alone.
Nah, my observation of cats' disinterest in moles predates my use of "liquids the moles might not like". :ROFLMAO:
Never tried it with moles, but have done that as a last resort with woodchucks. Seemed to work.
I tried one application of that and it didn't seem to have much effect. Maybe didn't cover enough area and the moles just moved to another part of the yard. Have to give it another shot.
   / Anyone have a solution to eradicating moles ?? #47
Or you didn't have grubs to begin with, and the moles are eating earthworms, like most moles.
   / Anyone have a solution to eradicating moles ?? #48
Trapped two more this week. We have nearly eradicated them… rarely see a run. If I do,I just place a trap on the main run, not a feeding run. If I catch a mole there, I place the trap again. Moles are solitary creatures and don’t share territory, but they will adopt an old run if abandoned… and bam, you get that rascal too.
   / Anyone have a solution to eradicating moles ?? #49
If it's a "U" shaped mound it's a gopher and any poison grain or pellets will work. Moles have a round mound and they eat works so there's a product called Talpirid that looks like gummy worms. I leveled the mounds with a shovel and when a new one popped up, I would locate the runway about 6" away from the mound. Then make a hole 3/4" or so to the runway, drop in a half of a Talpirid worm and seal the top of the hole you just made so light doesn't get down the hole. Think i've only had two come back on 5 acres since I got rid of them several years ago. Neighbors on one side has lots of them but none here.
   / Anyone have a solution to eradicating moles ?? #50
Since owning and operating ranch for last 30 yrs, the moles have really taken-off around the 2-acre house area. I use cinch traps for gophers and have caught 100's of them and have them under control; the moles I do not.
Looking for solutions that one person can implement to start knocking out these pests. I know they are moles, not voles or gophers...I really would appreciate your help and suggestions on any means you have been able to successfully eradicate them. Thank you very much !!
I did have grubs and sprayed for them which helped but the most effective way I found was the poison pellets. I poke a hole in the active tunnel try not to collapse it drop a few peanuts in and cover hole with loose soil. Do this all along active tunnel not as satisfying as pulling out a trap with a dead mole in it but it has worked for me every time except once. I did stray from the process last summer where one was eluding me by a gate in the fence around the dog pen . I would smash the mound the mole made cause the pellets were not killing him so I use a pointed crow bar and stabbed the hole and all around it (it would go 1 1/2' down then poured a gallon of gas in the holes .(don't light it) I flattened the trails and mound and he was gone.
1995 Chevrolet K2500 Pickup Truck, VIN # 1GCGK29F2SE237154 (A57453)
1995 Chevrolet...
JCB Loadall 506B Telehandler (A57453)
JCB Loadall 506B...
2012 TAKEUCHI TL12 SKID STEER (A60429)
2012 TAKEUCHI TL12...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
2025 MMS MS36C (A53317)
2025 MMS MS36C...
