2023 Mule Pro MX EPS?
/ 2023 Mule Pro MX EPS? #61
If your gonna be doing alot of woods riding. Buy some CV boot protection. Replacing cv joints can be expensive, especially if you have a shop do it
/ 2023 Mule Pro MX EPS? #62
Actually the aggressive lugs offer more traction in most conditions. I doubt they'll be hard at all on grass unless he intentionally spins them, no different than a tractor with turf or even R4's. I'll tell you what CAN be hard on grass and that's my little Pioneer 520 anytime you turn it very sharp.
You should see our yard with these aggressive tire lugs. Its like you shoveled up little pieces of it out. No power involved, just turning. We do trail work and can see where we came and went from quite well. Nonethless, they priced us 6 new tires for about $1500 so we kept of oem ones.
/ 2023 Mule Pro MX EPS? #63
I can see how a 6x6 making turns might chew up the yard even with open differentials. Neither the Mule or Deere 3520 with R4's disturb my grass, unless the ground is squishy wet. But the Pioneer 520 with no differential is a different story, heck it'd do so with slicks!
I have noticed the Mule Pro-MX leans to one side. Seems to be a common problem.
/ 2023 Mule Pro MX EPS? #65
I never noticed but I'll measure mine when in the garage. What side is higher on yours?
/ 2023 Mule Pro MX EPS? #67
The new wheels and tires are on. Very pleased.
Looks really good with the bigger tires, I'm sold, I'm putting them on mine. What differences have you noticed as far as power, acceleration and overall speed? Worse, better, not much difference? Any clearance issues? Thanks in advance
I have not noticed any difference in power, but I only had the stock on for a couple of short rides. Traction is much improved as well as ground clearance.
Now I can't wait to go get the junk mail. LOL
/ 2023 Mule Pro MX EPS? #70
I have aggressive lug tires similar to dj1701 on my ATV with snowplow and am continuously amazed at how well it does in all kinds of snow conditions.
/ 2023 Mule Pro MX EPS? #71
The link is for 4 x 156mm bolt pattern wheels for a Pro FXR. I believe the Pro MX uses 4 x 136mm.
Only the pro mx KAF700A series uses 4x136. The KAF700B, C, and D all use the 4x156 bolt pattern. Can be very confusing because many aftermarket companies don't differentiate models
/ 2023 Mule Pro MX EPS? #72
I see thanks Buckeye!
The right side of my MX appears to be about 1/2" higher than the left. I'll run the left side F&R springs up to level it.
Couple more of my favorite Mule. I love taking pics and this is just another reason to get out with my camera.
/ 2023 Mule Pro MX EPS? #75
It looks nice in camo, and so complete! First thing I did was remove the roof and doors.
I did level mine today. Puffed all tires to 12psi then increased preload on left front and left rear until level.
Looking good. (y) We used real cameras as well. You guys sure don't have much snow there. Less than normal this year?
Been a easy winter here south of Buffalo. We usually get hammered.
I was going to remove the doors but those Carnivores really kick up the mud.
/ 2023 Mule Pro MX EPS? #78
I'm not a fan of the doors either bit keeps mud off....to a certain degree. I like the roof and I added a windshield.
I am gonna take the bars off the cab so I can reach into the bed though
/ 2023 Mule Pro MX EPS? #79
I noticed that when looking at your wider tires and wheels and can see that happening. I get no spray, dirt, or mud with doors off with stock tires so that's why the doors have stayed off. But the P520 (stock) tires sprayed everything from the road on my leg so those doors went right back on.
2023 Caterpillar 289D3 Skid Steer (A64047)
2023 Caterpillar...
2022 EZ-GO ELITE...
159115 (A60430)
159115 (A60430)
Stone CP13 Asphalt Roller (A64047)
Stone CP13 Asphalt...
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
2024 GMC Yukon Denali 4x4 SUV (A61574)
2024 GMC Yukon...
