Starting my bridge!!
/ Starting my bridge!! #1
Doorman63
Gold Member
Illinois
Kubota L2501HST
In my barn thread I mentioned a bridge build and people wanted me to post when I was building it.
Todays the day!!!
Approx 20’ span
Approx 7-8’ wide
2x6 tubes for the stringers
A center 2x6 tube under the stringers
3x3 tubes for cross members
6x6 treated timbers for the “foundations” on each end.
End goal is to drive a vehicle across!
355A08B7-95DA-434F-8891-D183F1F0A417.jpeg7A6ED68D-65D3-4424-B5D5-FA348C290000.jpeg0B3362D6-7685-49BD-8B38-6A3BF3C8D816.jpegED42B136-0E1B-45DE-BB02-CA918B16F740.jpeg
/ Starting my bridge!! #3
Todays the day!!!
Approx 20’ span
Approx 7-8’ wide
View attachment 786740View attachment 786742View attachment 786743View attachment 786745
This should be good.... Watching.
What'd those 2x6's cost ya?
/ Starting my bridge!! #5
They were free.
A manufacturer of a high speed door we install uses them as a cradle for their doors
I have over 100’ of tube in various lengths in a rack in my barn.
WOW! Free, new(ish) steel tubing? Good for you!
/ Starting my bridge!! #7
subscribed as well looking forward to see the progress...
Is there a big flow fluctuation in this stream ? One thing to keep in mind is the vegetation always die under bridges, then the water erode the bank below the abutments since there is no vegetation to hold the soil together.
It gets going fairly well when it rains more than a couple inches.
It’s run off from a field next to me.
I’ve seen it completely dry before
My preference would be for a concrete foundation vs wood.
I agree.
Budget doesn’t allow for it currently…..so far I’ve got $180 in the 6x6.
When they pour the slab for the new barn I may order an extra yard or 2 and fill around the beams
Progress so far.
Taking a break for some ice water and swapping of laundry.
This is the center stringer.
Gonna weld up the outside stringers after my break
Gonna be tricky getting the other 6x6 across the creek
We have a crossing I can drive my tractor across….1.5” of rain last night made it really slimy!
/ Starting my bridge!! #12
I'm sure it will be fine. Looking forward to seeing the finished results
1 stringer welded!!
1/8 7014 rod-110amps
Miller Blue Star 185 welder
47F058D7-7B10-46A1-933A-AF562ACA8659.jpeg716DE3A6-8AFC-4EE1-B6B0-335D3E4D71B3.jpeg3FC524EB-3B83-4346-B798-6BD1730C8FE8.jpeg455EAAE6-573B-47EC-BE56-B45D7811D16B.jpeg
/ Starting my bridge!! #14
following, interesting design.
/ Starting my bridge!! #15
Good looking stick welds. I didn't use one enough to get good at stick welding. After I bought a good MIG, I never went back.
I’ve got a wire feed
For a project like this it’s really slow.
Stringers complete!!!
2x4 is just to show how the cross tubes will go.
They will be 3x3x3/16..8’ long 0CCBB721-3FE7-46F6-A08F-7A6CFA65E63D.jpeg751BA632-190B-4065-9959-ECD538656F0B.jpeg
That’s about it for today!
Level-ish
Square-within 3/4”-hard to square big things solo
I’ve got 6 more cross pieces to cut/notch/weld
Then the deck……might do steel tubes flat where the tractor/truck drive and than wood for the rest 8E80F362-3B96-4636-84C1-F32D1797218A.jpeg5C8884E5-54E3-432E-B8D7-A22B94E6AE40.jpeg354E80E8-915E-4413-AF1A-405B83C4BE18.jpeg1A369EB6-C2BD-41FE-A6D6-5F40EFBAA21D.jpeg
/ Starting my bridge!! #20
ROTARY SCYTHE (A63291)
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
John Deere 561M Baler (A63111)
John Deere 561M...
2022 EZ-GO ELITE...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
