Flow Control
/ Flow Control #22
I've decided to scrap the valve and make a restrictor from a pipe coupler. Maybe something as simple as washer with smaller hole in the center. Anybody besides me think that would work?
/ Flow Control #23
In the past, I've drilled and tapped one of the adapters somewhere in the line I'm trying to control the flow, but didn't tap all the way through, just like 6 to 10 threads.
Then just cut a threaded section of a bolt with the same thread I tapped the adapter with and drilled a 1 mm hole in the center and cut a slot with the angle grinder for a flat screwdriver. Lastly, I just thread this threaded stud in the adapter till it bottoms on the threads so it won't come loose.
That way, it's easier to fine tune the flow as I can simply make other short threaded studs and change the diameter of the hole in the center.
/ Flow Control
Update: So I finally was able to find the needed adapters to attach my flow control valves. I had to mount them by the hydraulic shocks because there wasn't enough room in the
valve box once the adapters and valves were included . I had the flow set to 0 when they were once installed and opened them both 1/4 of a turn. started the tractor up and boom!, the response was just about to where I wanted it. Ill probably play with them some more to get it right where I want it.
Once again , thanks for all of the help with this!
/ Flow Control #27
Nice! Thanks for the update.
Nice and neat installation too. Doesn't look like it's to hard to reach and adjust if needed.
Athey 7-12 Force Feed Loader (A62679)
Athey 7-12 Force...
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
John Deere 7230 (A62180)
John Deere 7230...
Informational Lot - Shipping (A63688)
Informational Lot...
DOBBS 48in Forks and Frame Skid Steer Attachment (A61572)
DOBBS 48in Forks...
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
