reading a dial caliper
/ reading a dial caliper #1
LittleBill21
Elite Member
PA
Mahindra Max 26XL, White
I feel almost embarrassed to ask this, but I need to confirm my numbers are correct.
in the photo is this approximately 47.62 mm?, its saddening, since I use a metric digital one a ton, but people love their old school.
/ reading a dial caliper #4
I’m reading the dial at 1.9665 which would convert to 49.949mm.
Get a digital Vermeer - One that will toggle between mm/inches/fractions and be done. lol
yea I do have one, this is a customer sending me a photo...
/ reading a dial caliper #9
1.866 or maybe 1.867. Digital caliper batteries dying is kinda a nuisance but the ability to transfer between metric and decimal and sometimes fractions is nice.
I bought one that uses a 2032. Has lasted over a year. and I use it easily 30-40 times a week.
/ reading a dial caliper #12
Yup! +/- .003 accuracy
It’s honestly probably .010 bigger. If you look close you can see that the right side is being held off because it’s not in the pipe straight.
/ reading a dial caliper #14
I use a caliper so rusty and old that I don't even try the numbers. I just hold the calipers against a known good measuring tape. But I'm in Arkansas, y'all probably expect that from me.
lol folks I just need to make sure i wasn't off by multitudes, after staring at the dial more I understand it better. we have 3 mm buffer, we don't need it that perfect ty.
/ reading a dial caliper #17
I have done a lot of quality work over the years, working with drawings, specifications etc. There is a new geometric symbol being used on drawings now. It was issued by the SAE early this year. So I just want to make every one aware of this addition. It is a tolerance symbol where as the dimension must be right on, with out deviation, perfect, got it. It's called " Dead Nuts " See attached.
/ reading a dial caliper #18
Is that NY DN or AR DN ? ;) :ROFLMAO: :ROFLMAO: :ROFLMAO:
/ reading a dial caliper #19
I can’t begin to tell you how many times over my career I had a customer ask me “tolerance?” “Can’t you just make it perfect?” My reply was always “sure I can, but each move of the decimal point to the left increases the cost by a factor of 10. How close do you want it?”
/ reading a dial caliper #20
Hwwwat?!! Heresy, I can't even...I bet as a kid, your room was quite messy.
CASE 610 Sprayer System 2000 Gallons (A63118)
CASE 610 Sprayer...
24in pin on excavator tooth bucket (A61307)
24in pin on...
2018 Mack CXU613 T/A Day Cab Truck Tractor (A60352)
2018 Mack CXU613...
2019 GENIE S-80XC TELESCOPIC BOOM LIFT (A62129)
2019 GENIE S-80XC...
2012 Keystone Alpine 3500RE 39ft. T/A 5th Wheel Travel Trailer (A61569)
2012 Keystone...
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
