reading a dial caliper
/ reading a dial caliper #22
At one time a long time ago, I ran a large G&L floor mill/ a HBM. It was a 7" bar machine with a quill. It also had a shaper attachment, 40 feet of column travel "x" or , I can't remember the vertical travel. The scales thru peep sights were all fractional. Beside all the hand tools, wrenches, scales, micrometers, tape measures you needed to run the machine, you also needed a steno pad and a #2 pencil with a good eraser. Easy eh!. I learned after 50 plus yrs in manufacturing you don't mix decimals and fractions. It's a "No No". Later.
Hwwwat?!! Heresy, I can't even...I bet as a kid, your room was quite messy.
lol the equipment can't hold that tight.
/ reading a dial caliper #24
i remember back in my machinist days...reading a vernier scale on a mic or caliper. & probably accurate as a scale if the machinist's eye is accurate. i quickly converted to dig readout so long ago. love the old tools though
/ reading a dial caliper #25
Digital batteries are a pain particularly in cold weather. Got a solar power assisted digital caliper for my unheated shop 17 years ago. Still on original battery.
/ reading a dial caliper #26
Yup! +/- .003 accuracy
I can’t begin to tell you how many times over my career I had a customer ask me “tolerance?” “Can’t you just make it perfect?” My reply was always “sure I can, but each move of the decimal point to the left increases the cost by a factor of 10. How close do you want it?”
I've always preferred the C___ Hair scale for Tolerances. Blonde ... pretty much the holy grail, red ... close enough, brown or black ... keep working.
/ reading a dial caliper #27
Yeah, you know highly inappropriate but dammit that's the way we talked! I am a pretty prolific user of swearwords, I blame it all on working on the factory floor at GM,Ha Ha. Or maybe it was when I was hanging structural steel, or working on the farm or well maybe I just learned it on my own.
/ reading a dial caliper #28
The calipers that offer a display in fractions have always made me scratch my head. I have nothing against fractions, but I have a hard time quickly visualizing if 23/64th is larger or smaller than 3/8th of an inch.
It is why normal ppl converted to metrics long time ago.
/ reading a dial caliper #29
Only time I convert decimal to fraction or millimeter, is when I trying to find a "close enough" drill bit (fractional)....
But there is this....
Must be something similar for Android or IPhone...
/ reading a dial caliper #30
I find that it's faster to read and get an accurate measurement with a standard dial caliper. the reason is you really need your caliper to be total parallel to the piece your measuring and the best way to do this is to rock the caliper on the piece and read the dial while you do it. The biggest/smallest reading would be the most accurate measurement.
But for a piece of pipe like this it prob dosnt matter much.
/ reading a dial caliper #32
Metric system is for bidet users.
I am not much for bidets, but having used both systems throughout my career, I sure wish the US would have adopted the metric system back in 1776. Everything is so much easier. But unfortunately my brain has become calibrated to think in inches, pounds, and BTU's.
/ reading a dial caliper #33
/ reading a dial caliper #34
As much as I hate to admit it; I agree.
/ reading a dial caliper #35
Anyone that doesn’t agree probably hasn’t spent over an hour measuring anything and then doing anything with the measurement’s. Try laying off a square building in inches and let me know how that works for you. Say it’s 30 ft square. The diagonal of that would be 42.42. Not 4 inches, .4. An engineer tape measure makes that an easier job but that’s basically just admitting metric is better but you don’t want to admit it. Next problem, let’s say you need to order concrete for a ditch that’s 28” wide, 14” deep and 300 ft long. Calculating in feet doesn’t work well. I convert everything to inches and divide back when I’m done. 28x14x3600. Then divide that number by 1728 to put it back to cubic feet. Then divide that number by 27 to get cubic yards. Let’s just do an easy problem next. Say you have a board that’s 47-5/8 of an inch that you want to cut in 3rds. That’s not that easy to divide out in your head. That same board would be 1200.09 mm. Anyone could easily divide that by 3.
/ reading a dial caliper #37
Alexa does a good job on conversions if you ask her right. Just tonight-
"Alexa, how many pounds is 66 grams?"
"...about 2 ounces."
"Alexa, EXACTLY how many pounds is 66 grams?
"Alexa, how many pounds is 66 grams EXACTLY?"
".... 0.1455052...pounds."
And Siri converted it to 0.15 pounds, on her first try.
/ reading a dial caliper #38
I don't have Alexa...
I don't have Siri...
What am I to do.....
/ reading a dial caliper #39
Oh no, your in trouble by now!:)
Just have to do it the way it was done before technolgy got us all into the same trouble.
I learned on a slide rule, and my mental approximations have been accurate enough to correct the errors from others hitting the wrong key on thier calculators.
Next question is would I trust Alexa or Siri with a correct answer all the time. The answer to that is, (drum roll) NO!!
/ reading a dial caliper #40
I've grown accustomed to multiplying by four when wondering about decimal inches equivalent to a know metric measurement. Example would be 18 mm times four would be a little less than 0.72 inches. Not exact by any stretch but so used to thinking in imperial making metric hard to visualize.
The U.S. definitely should have followed thru on going metric back in the seventies!
Something I did early in my career was memorizing decimal equivalents up to 32nds. Then its fairly easy to convert 64's to decimal by considering the nearest 32nd then adding about 15 thou. Have rarely used decimal equivalent charts.
2015 JLG G12-55A 12,000lb 4x4 Rough Terrain Telehandler (A61572)
2015 JLG G12-55A...
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
Headsight Autopilot Kit for Claas (A63117)
Headsight...
2 Wheel Homemade Trailer (A64119)
2 Wheel Homemade...
(5) 2" X 20' STEEL PIPE (A64281)
(5) 2" X 20' STEEL...
2015 IC Corporation PB105 School Bus (A61568)
2015 IC...
